Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
Unread 16-10-2009, 11:29
MachineSMMC MachineSMMC is offline
FRC #3026
MachineSMMC is an unknown quantity at this point
Download from Crio to Labview
Is it possible to download from Crio to Labview. I want to be able to pull the code off of the Robot and put it back on the PC to make sure we are editing the correct program. (we lost all of our programmers last year)
Thanks
Chris Tellers
Team #3026
Orange Crush
Unread 16-10-2009, 12:53
Re: Download from Crio to Labview
The file on the cRIO is an executable program generated from the LabVIEW project. You can retrieve it from the cRIO if you want (using ftp), but you won't be able to do anything with it. It is not in a form that can be edited, and there aren't any tools to turn the executable back into the VIs that were used to create it.
Think of the VIs you edit as the equivalent of eggs and flour and sugar, and the .exe file on the cRIO as a baked cake. If you don't have the ingredients, you can't really use one cake as the raw material to make another one.
Unread 16-10-2009, 12:56
Joining the 900 Meme Team
FRC #0079
Alan, please correct me if I am wrong but would it be possible to pull that executable off and compare it to an executable produced by code they do have?(I am assuming they are trying to find which version of code they last used and have all their code) Similar to when you compare the checksums of files to make sure they downloaded properly?
Unread 16-10-2009, 13:37
Assuming they haven't made any configuration changes to their development system in the meantime, that seems like a very good suggestion.
Basically, bake another cake and see if it looks and tastes the same as the one you already have. If they match, you know you have the right recipe.
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 09-03-2009 22:10
How to download and keep a program on crio zackcool123 Programming 2 16-02-2009 18:22
Crio image download brainsdmaner FRC Control System 2 15-02-2009 01:06
Trouble Downloading from LabView to cRio MikePres FRC Control System 0 15-01-2009 16:17
Download Programs Off the cRIO jwdickson FRC Control System 1 10-01-2009 17:29
