You may possess me without penalty.
Unread 18-10-2009, 03:41
955Tyler's Avatar
955Tyler 955Tyler is offline
FRC #0955 (RaiderBot)
955Tyler is an unknown quantity at this point
Digital inputs on old FRC
Hey all,
My team is constructing an off season robot that is using one of our old control systems. I have everything programmed and working except i'm having troubles with the digital inputs. I need to read pressure sensors, and i cant get the digital inputs to change via the pressure switch or any manual switch. I'm printing the digital input and it is stuck at 1. Is it 1 by default? any suggestions for testing? or am i missing something completely? its been a awhile since i have done anything with the old FRC so maybe i have just forgot something.
Thanks everyone!
Unread 18-10-2009, 09:47
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: Digital inputs on old FRC
Here is a link to the doc at IFI:
http://www.ifirobotics.com/docs/anal...al--i-o-rc.pdf
State of the input is based on which one you are looking at...
Hope this helps...
Ted
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 18-10-2009, 09:48
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
The default code contains an example of how to control a compressor on relay8 using the pressure switch on dig_in18, so take a look at that first for an example on reading digital inputs.
--Make sure you have digital_io_18 set to input
--Try a different input, in case the one you're using is broken
--The inputs have pull-ups enabled, so they're naturally high by default. The pressure switch should be connected so that it is pulling the input low, i.e. the switch is connected between the signal line and ground.
--Ryan
FRC 766, 2015-, Mentor
Unread 18-10-2009, 14:16
dtengineering's Avatar
AKA: Jason Brett
It is possible that your code is correct, but the pressure switch is not working properly... not likely, perhaps... but possible.
Have you tried checking the pressure switch with an ohmmeter to see if the contacts are closing and opening?
Alternatively, have you tried hooking up a switch (or just using jumpers) on the i/o pin to see if your code can read a "known good" switch?
You probably have, but just thought I'd add a "check the hardware" comment in amongst all the helpful software advice.
Jason
Unread 18-10-2009, 17:30
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
If you are sure that the switch is working (by using a multimeter) and you are sure your code is correct (by using the default code or code tested by another team), then you should check for metal chips in/around/under the input pins. I've seen metal chips create a short that causes all pins to pull high or low, which makes the input "stuck" either on or off.
Unread 18-10-2009, 23:44
Tyler,
To be sure, you are using a pressure switch and not a pressure transducer? Both were provided as KOP supplies in some of the past years. The transducer is an analog device, while the pressure switch is a just that and is connected to a digital input. Using a PWM cable, you cut off the connector at one end, pulled back the 5 volt wire and insulated it, then attached the signal and the ground wire of the PWM cable to the switch.
Digital Inputs Driver Station dboisvert C/C++ 2 25-02-2009 20:09
Digital Inputs? Straberrie Programming 4 15-02-2009 01:47
Digital Inputs + Auton? Straberrie Programming 13 13-02-2009 11:28
Digital Inputs KRibordy C/C++ 5 25-01-2009 00:35
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
