Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 17-10-2009, 23:22
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
[FTC]: FTC Cad Parts
Is there any way that I can download the entire FTC KoP from www.3dcontentcentral.com ? All of the parts there are perfect but it's a pain to download each part individually.
Unread 18-10-2009, 08:39
Monty Python Monty Python is offline
Monty Python has a spectacular aura aboutMonty Python has a spectacular aura aboutMonty Python has a spectacular aura about
Re: [FTC]: FTC Cad Parts
Give this url a shot instead.
http://www.catalogds.com/db/service?...gory=FTC_K OP
Good luck!
Unread 18-10-2009, 09:56
BradMello's Avatar
Broken Arrow
Team Role: Driver
I found this link somewhere else, and the only problem is that I am using solidworks 2008-2009. After some searching around on the web, I found some forums that were discussing importing pro/E parts into Solidworks, and while some of them say that it is possible, every time I try to, nothing happens.
Unread 18-10-2009, 14:12
I know that it's possible because I know that my team did, but I'm not exactly sure how we did it. Sorry I can't be of more help.
Unread 18-10-2009, 14:27
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
i just downloaded each of the parts for all the programs i have it may take a while but it goes fairly quickly
Unread 18-10-2009, 17:13
BradMello's Avatar
Broken Arrow
Team Role: Driver
Yeah that's what I'll end up doing, I just wanted to check for a faster way before doing it like that. Marie, do you have a solution?
Unread 21-10-2009, 08:04
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Let me see what I can do. You want the FTC parts in one location in SolidWorks format - correct?
Marie
Unread 21-10-2009, 16:20
BradMello's Avatar
Broken Arrow
Team Role: Driver
Yes, available as one download
Unread 22-10-2009, 14:26
AKA: Andrew Remmers
for Pro-E i know you can download everything at once
Unread 23-10-2009, 00:04
Legally, I do not have permission to do this - however, since most of the parts were designed in SolidWorks originally, I will ask the vendor. This might take awhile. We are very sensative to utilizing model files designed by others. However, I created a series of youtube videos for collegiate FSAE teams that might be helpful to show you how to use 3dContentCentral more effectively. You can actually drag the component right
from 3dContentCentral into your assembly.
View the video on youtube, http://www.youtube.com/watch?v=Oy_MZ... FAF31&index=2
Although these movies were created for car design, the technique is the same. Select the First Robotics or VEX Robotics category under User Category for My Favorites. Create a common directory for
all 3DContentCentral parts when you download.
Remember to customize your Design Library to include this folder of parts - it will really make life easier. You can drag them into additional assemblies.
Tip: Think about subassemblies first - how would you assembly this physically? What parts move and what are fixed. Use reference axis for rotation to mate to. Marie
[FTC]: [FTC]: 2009 Kit Of Parts CAD files Andrew Remmers FIRST Tech Challenge 15 16-09-2009 11:12
[FTC]: FTC parts website? ttldomination FIRST Tech Challenge 3 29-01-2009 00:15
[FTC]: CAD Models of Tetrix parts? Madison FIRST Tech Challenge 2 23-11-2008 08:49
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
