Go to Post Aww, but I ENJOY getting all up in arms about something that's ultimately inconsequential! - Cothron Theiss [more]
Unread 25-10-2009, 21:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Clear plastic sheeting?
I've noticed that a LOT of teams use clear, thin plastic sheeting on their robots. Thin, but still very rigid, and clear (but still a bit flexible). Many teams used it this year to go around the outside of their spirals.
I want to call it acetal, or acetate - but when I went to look on mcmaster the sheer amount and variety of plastic sheeting made be scratch my head a bit. I know it isn't vinyl, which is not nearly as rigid and is quite heavy. So what's the right name for the thin semi-rigid plastic most teams use on their bots?
You can see it here on Foley Freeze on the outside of their spiral:
http://www.chiefdelphi.com/media/img...48d13528_l.jpg
Unread 25-10-2009, 21:33
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Re: Clear plastic sheeting?
Its probably just polycarbonate sheets or acrylic sheets, I'd lean more towards the polycarb though as acrylic like to shatter...
2012-2016 Wave Robotics Team 2826
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Its probably polycarbonate (also called Lexan).
Highly impact resistant and can be bent to shapes using a heat gun or other heat source.
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 25-10-2009, 21:37
Chris is me's Avatar
AKA: Pinecone
It's polycarbonate. Acrylic sheet I would not reccomend as it could not withstand any force on a competition robot. Polycarbonate is rather easy to work with, can roll up, is relatively flexible, and can be bent with heat.
With proper use, you could even use very thick polycarbonate sheet to build your whole robot if you wanted to.
Unread 25-10-2009, 21:43
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
We use 1/16th lexan (polycarbonate). we use a heat gun to bend the lexan and waterjet to cut out the shape
Unread 25-10-2009, 21:46
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
McMaster-Carr is a good source.
Ed Barker
Unread 25-10-2009, 22:09
Gdeaver Gdeaver is offline
FRC #1640
You may find a local Glass company that could help with poly carbonate and save the shipping.
Unread 25-10-2009, 22:12
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Definitely polycarb. Trust me, you do NOT want to use acrylic sheets. We, for some odd reason, had some lying around the shop, mistook it for polycarb, and started trying to get it on the robot. We realized our mistake when it began cracking and shattering when we started putting the rivets in.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 25-10-2009, 22:15
Yes, I've always used polycarb, but I've seen teams use acrylic, not in any load taking location though.
I'd look for a local source before turning to mcmaster, polycarb can get heavy and shipping can get expensive, as well as the polycarb.
Unread 25-10-2009, 22:27
AdamHeard's Avatar
Lead Mentor
We used .020 and .030 thick polycarbonate on our bots this year.
You actually don't need a heat gun to bend it, it bends just fine in a normal sheet metal break. It works out much cleaner and nicer. Also cuts nicely in a shear.
Unread 25-10-2009, 22:35
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
McMaster is a little funny about what they define as film vs. sheet. 0.040" and less is film and 1/16" and greater is sheet. Go figure. We have usually used McMaster 8574K29 0.040" film in the past.
Unread 25-10-2009, 23:27
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I've bought polycarbonate as thin as 0.010 to cover the outside of the robot with. That thin it comes in a roll. 48" wide by however long you want. It seemed like they called anything that was "rollable" film and stuff that shipped and stored flat "sheet".
Try to find a local plastics supplier that supplies to sign and screen printing shops if you are looking for large pieces of thinner film. If they don't have it, they can probably get it for you with their regular deliveries. Shipping will kill you if you have to buy it mail order.
I used to use Calsak Plastics when I lived in ATL, but they don't have a warehouse in your part of the country. Their website is http://www.calsakplastics.com , at least you can look at a pretty wide range of what may be available. Wish they had a warehouse near here in MN. I'm still looking for a polycarbonate supplier here that will charge me less than retail
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 26-10-2009, 00:47
dtengineering's Avatar
AKA: Jason Brett
Polycarbonate sheet can also be bent cold in the box and pan brake and other sheet metal working tools.
Thin polycarb also cuts quite nicely with a sharp knife. Thicker pieces respond well to woodworking equipment... table saws, jointers, bandsaws or jig saws come to mind.
Jason
Unread 26-10-2009, 01:25
REVving up for a new season
FRC #2848 (All-sparks)
Jason
what in the world do you do with a jointer and a piece of lexan?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 26-10-2009, 01:29
AKA: Pinecone
I'm not sure if I'm referring to anything by the right names and everything, but I think you can use a jointer with an obtuse-angled fence to make different "rounded off" (kind of) edges on thick pieces. I'm sure there's a more technical name for this process I'm forgetting, but my team and I did this to finish some structural pieces.
Is 9.3.9 clear to you? soap108 Rules/Strategy 2 12-02-2007 18:10
Clear or Plastic Board for Electronics?? D_Price General Forum 3 17-01-2007 10:05
ALL CLEAR archiver 2000 0 23-06-2002 22:19
Polyethylene rigid sheeting BigRedLawyer OCCRA 1 14-10-2001 20:44
