Go to Post Some people need the 2x4. - Ether [more]
Unread 26-10-2009, 09:40
xanarchyx xanarchyx is offline
Capt' of Manipulator
AKA: Collin Matthews
FRC #1714 (More Robotics)
xanarchyx is an unknown quantity at this point
pic: 1714 Polycarb prototype Crab Drive (backdrop1)
Unread 26-10-2009, 09:43
Joining the 900 Meme Team
FRC #0079
Re: pic: 1714 Polycarb prototype Crab Drive (backdrop1)
How grippy is the belt? Have you done any testing to see if the belt breaks when being pushed sideways? Would there be a benefit to using dual sided belt?
As an additional question, is the polycarb just for show or will the actual modules be made out of it? It looks gorgeous.
Unread 26-10-2009, 10:03
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
1714's robots are always made out of polycarb, so if they were to make a crab system for their robot i don't see why they wouldn't use polycarb...
2012-2016 Wave Robotics Team 2826
Unread 26-10-2009, 10:04
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
1714's robot from last year
Unread 26-10-2009, 10:18
FRC #0079
Originally Posted by Lil' Lavery View Post
Just learned my thing for the day then I stand by what I said about being gorgeous.
Unread 26-10-2009, 10:22
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I'm a fan of the "carbdrive"
I'm also a glutton for pun-ishment.
Hi!
Unread 26-10-2009, 10:43
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
1714 the Anti-Atkins bot. All carb-all the time....
Unread 26-10-2009, 10:51
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The joints holding the top plate to the sides, and supporting the bevel gears scare me a little. Polycarbonate is acceptably strong, but rather flexible—so much so, that it's a bad idea to assume that it will be rigid under normal driving loads. This will wreak havoc with your bevel gears, unless the structure supporting the modules is rigid enough to overcome the tendency of the modules to distort. (Then again, it's more an issue of efficiency rather than failure; those gears have large, strong teeth.) At the very least, put some bracing on the open sides, to cut down on the parallelogramming action (due to side loads). You're definitely right to put a support ring on the bottom of the gearbox.
In truth, I don't think the polycarbonate is a good choice here. Aluminum gives you several times the stiffness, and several times the strength, at only about twice the weight. Besides, if you're concerned about appearance, you can always polish or anodize it.
Additionally, what's preventing axial motion of the gears and pulleys? It looks like you're using simple set screw shaft collars, and a pulley with a set screw hub. Especially if you allow the gearbox to flex, this arrangement will cause you no shortage of annoyance. Consider adding spacers to physically prevent axial motion. And I can't tell from this image, but if you're transmitting torque through set screws, you'll probably have suboptimal results. Please track down the resources necessary to add keys and keyways—they're vastly more reliable.
It looks like you're relying on that belt for traction, as well as power transmission. It would be wise to test that in the pre-season, to see how much it wears when running on carpet (and whatever else you think the 2010 floor surface might be).
Unread 26-10-2009, 11:32
Chris is me's Avatar
AKA: Pinecone
So I'll just ask you guys this stuff here since I'm too lazy to bump down an email.
If you guys don't call it "carb drive" I'm quitting the team.
How do the belts stay on the wheel? It seems like with tons of side load (turning at full speed, being rammed) they could wear away and pop off if they're being held on just by the teeth in the belt.
Is there going to be a full test chassis so that we can ram things into it all day and see what happens? Have you guys run this through its paces yet?
How much does it flex?
It looks wonderfully cool.
Unread 26-10-2009, 11:44
NickE's Avatar
NickE NickE is offline
_
Are bearings being used? I can't really tell whats going on on the intermediate shaft.
Unread 26-10-2009, 11:46
AKA: Pinecone
There are bearings on the intermediate shaft.
Video from other images:
http://www.youtube.com/watch?v=f2OXqa8BZX8
http://www.youtube.com/watch?v=mA23sg6UubI
http://www.youtube.com/watch?v=2qKl42vqjcU
http://www.youtube.com/watch?v=3cXdk4C9aQc
Unread 26-10-2009, 12:48
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
Two things.
1. I see a potential problem with the crab drive not being stable enough because I don't see a place where the load would be delivered onto the module safely and effectively.
2. There might a problem if the polycarb breaks or bends too much. You would have to replace the entire drive module with new polycarb. I would suggest doing some stress anylises in the pre-season.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Unread 26-10-2009, 12:51
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
What DP are those bevel gears?
Watch out for flex in the gearbox causing tip-loading on the bevel gears. Make sure you beat the heck out of those things to ensure the gears will hold up even under worst case shock load.
We uhh... had some issues... uhh... with that sort of thing at one point. Yeeeeeahhhh....
-John
Unread 26-10-2009, 13:46
legotech25's Avatar
legotech25 legotech25 is offline
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
legotech25 will become famous soon enoughlegotech25 will become famous soon enough
Send a message via AIM to legotech25 Send a message via Yahoo to legotech25
Hey, did you guys ever replace the top and bottom plates with polycarb? It looks like you're still using the laser cut acrylic parts, which would be a problem (it will shatter like no other). But once that happens, I like it!
Just a thought, maybe the bottom circle would be best made from Acetal? Just to reduce the friction and other drive forces... You might want to run that by AJ, Mr. Laabs, and/or Dad first though.
Team Captain - More Robotics 1714
2009 Milwaukee - Chairman's Award
2008 Milwaukee - Chariman's Award
2007 Cleveland - Kliener Perkens Buyers Caufield Entrepenureship, Engineering Insparation
2007 Milwaukee - Kliener Perkens Buyers Caufield Entrepeneurship, Website, Motorola Quality Underwriters Laboratory Safety
2006 Atlanta - Rookie Inspiration
2006 Cleveland - Rookie All-Star, Safety Runner-up
2006 Milwaukee - Rookie All-Star, Safety Runner-up
pi = 3.141592653589793238462643383279502884197169399715 10 ^_^
Unread 26-10-2009, 14:04
AKA: Pinecone
Yeah, I noticed that... Not something that should be on the final module for sure, probably just there for photo purposes I think.
I know a lot of teams use acetal right now to support their modules (like here). I'd recommend it solely based on what I've heard from other people.
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 13-01-2009 20:42
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
