Go to Post This is an engineering competition. Do some. - JVN [more]
Unread 26-10-2009, 16:52
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: pic: 1714 Polycarb prototype Crab Drive (backdrop1)
Yes, the final one will be made out of polycarbonate. After four years of building with it, we are confident it will hold up. As pictured, the top and bottom are acrylic because we wanted to laser cut them. American Acrylics is getting a CNC router, so they will be made out of polycarbonate eventually.
The belt is quite grippy. I dont have any numbers, but it seems to hold quite well. It is a single sided belt. We tested a double sided belt, but they have a nylon backing on both sides, and are less grippy.
Keep in mind this is only a prototype, and was put together quickly and cheaply. We do plan to put cross bracing to prevent flexing, if it needs it. Right now, we are just using set screws, but plan on using a hex shaft held in with snap rings. One of the things we like best about the module, is the belt for power transmission is also used for traction. We are planning to use a wider belt in the future.
The wheel has a groove the width of the belt for the belt to ride in. With it properly tensioned and aligned, it will stay on.
As for the DP of the gears, I will have to get back to you Wednesday.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 13-01-2009 20:42
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
