Go to Post 32% of the teams in any division will be or could be in eliminations. And any one of those could be YOU. If you aren't ready, you will be eliminated. If you are ready, you greatly increase your chances of winning. - EricH [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 20-10-2009, 17:50
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
[OCCRA]: Keyangs on Spikes
Can we run two non-shaft Keyangs off of a single Spike? Is this too much power for a Spike?
Kettering Motorsports
Unread 27-10-2009, 09:50
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: Keyangs on Spikes
This is possible as the motors are very weak. Use the 30 amp fuse.
Mike Martus
Unread 16-11-2009, 10:04
Apartheid's Avatar
Apartheid Apartheid is offline
None #0033
Apartheid is an unknown quantity at this point
I would use the 35 amp fuse
Dosen't Windows 7 realize that some of us still use serial ports with HyperTerminal?
Unread 16-11-2009, 16:44
apalrd's Avatar
More Torque!
VRC #3333
Can't put a 30-amp fuse on a Spike; they're only rated for 20 amps.
Unread 17-11-2009, 00:21
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
They're only rated for 20 amps, and they come with their own 20 amp fuse. Although this fuse is replaceable with an auto-reset fuse, I would not suggest replacing it with anything other than the 20 amp auto-reset fuse. We've burned out a few of them with very little effort at all, they're not one of those things that's rated for one value but can stand much higher.
As for wiring them to the same Spike, that depends on the Keyang motor ratings. I don't know how much current they draw, however, that kind of motor generally is very low-power in comparison to other types of motors (since the worm gear reduction has so much torque, they design the motor with less power as to not strip it out, and because it's not generally necessary).
If at all possible, check the specs. If not possible, my instinct says it should be okay. Just keep the 20 amp fuse somewhere in the line.
Unread 17-11-2009, 09:32
Apartheid's Avatar
None #0033
I might be unclear on the question, but what is a Keyang?
Unread 17-11-2009, 17:51
apalrd's Avatar
More Torque!
VRC #3333
A Keyang motor is a motor that is included in the OCCRA Kit of Parts. It is a automotive seat motor, is fairly small, is a worm drive motor, and spins sorta fast. If you want to compare it to a FIRST KOP motor, I would have to go somewhere between a window motor (since it is a worm drive) and a RS545 with a BB transmission (like what we used for the suck on the FIRST robot if you recall) for speed, but a bit slower and less powerful. They aren't that powerful, but they have a double-ended squared hole so you can mount a shaft on either side. Thus, you can chain several together to get more torque. We use two on the suck roller on the front. Actually, there are two types of Keyangs: one has a square hole (the kind that we are talking about) and the other has a shaft. The shafted kind is an automotive liftgate motor, and is slower. We use one of those to extend our arm.
Unread 18-11-2009, 08:52
Apartheid's Avatar
None #0033
What is a KOP Motor?
Unread 18-11-2009, 17:19
apalrd's Avatar
More Torque!
VRC #3333
Kit Of Parts.
BTW: I do not find the palardyville funny. I am sure you are trying to bug me.
Unread 19-11-2009, 09:36
Apartheid's Avatar
None #0033
I don't know what you are talking about. My last name is Palardy...
Spikes in C++? gravethief13 C/C++ 2 02-02-2009 18:39
Using 2 different keyangs Mikhail_Pham Motors 1 01-02-2008 13:43
SERIOUS Issues With Keyangs, Bending/Twisting Drive Shafts NoSkaOnTheRadio Motors 13 16-02-2007 13:51
Spikes? st28 Programming 2 24-02-2004 11:36
Connecting 2 Keyangs to a Victor? Jim Meyer OCCRA 3 14-10-2001 20:33
