Go to Post If I was a balding man, and Dean Kamen signed MY head, I'd immediately make my way to the nearest tattoo parlor and have them make it a permanent fixture. I wouldn't have washed it off! Just saying. - Carolyn_Grace [more]
Unread 24-10-2009, 18:21
ethan_orion ethan_orion is offline
FTC #0071
ethan_orion will become famous soon enoughethan_orion will become famous soon enough
[FTC]: DC Motor Speed
Our team is trying to get our DC motors to spin as fast as possible.
We are currently running on the teleopbasic template.
What resources or options are out there to increase the speed of the DC motors?
Thanks,
Ethan
Unread 24-10-2009, 18:29
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: [FTC]: DC Motor Speed
What do you mean by Speed?
Mechanically you could speed up whatever mechanism by placing a larger sprocket/gear on the motor output and then placing a smaller spocket/gear on the mechanism.
Programming: I'm pretty sure you just put it to max power and that is the max speed.
The Motor only spins @ 154 RPM's, so its not extremely fast.
R.C.
MadTown Robotics Team 1323
Unread 24-10-2009, 18:39
FTC #0071
We have geared up the motor to increase the speed.
Are the templates pre-programmed with max speed?
I'm still figuring out labview.
Hmm.. 154rpms. okay. Thanks
Unread 26-10-2009, 14:33
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Yes they are. Notice the VI Calculate Power from Joystick. This VI has an input called throttle. The default value for throttle is 50, but in the teleopbasic template it is set to be 100; e.g. full power can be output from this VI into a Move DC Motor VI. If this input is set to be 50 only half of the full power will be output from this VI.
If you have more programming questions feel free to post them in the FTC Community site on ni.com.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 27-10-2009, 12:10
JohnFogarty's Avatar
AKA: @doctorfogarty
In order to acheive max speed use large to small gear ratio because direct connecting the battery to the motor will give you the max speed of the motor.
John Fogarty
Unread 27-10-2009, 13:11
If I remember correctly, last year the TETRIX folk warned against gearing up drivetrains using the 12-volt motors after a series of gearhead failures. They recommended either direct-driving or gearing down the motors. This was a recommendation for drivetrains, so I'm not sure if they make similar suggestions for other applications. We broke three gearheads last year on a geared-up drivetrain and the problems went away when we changed to a slower design.
I know a lot of teams are planning on heavily gearing up wheels to shoot balls this year (including our own FTC team) and I expect it to work pretty well since the intertia of a whiffle ball is a lot lower than that of an entire robot. Just in case, we have a stock of spare 12-volt motors and a design that lends itself to rapid swaps.
Unread 28-10-2009, 10:59
AKA: @doctorfogarty
I do remember that, we blew 2-3 motors ourselves even one at nationals. It really depends on what you need the motor to do. Like if all you want to speed up is a wheel then it shouldn't be too much of a problem.
John Fogarty
Unread 28-10-2009, 12:31
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Whether it is a problem will depend on the size of the wheel and the function it performs. A large traction load on a big wheel could easily overheat a geared-up motor. That is why it is much more common practice to gear down.
Richard Wallace
since 2003
Unread 28-10-2009, 12:36
AKA: @doctorfogarty
The thing i find funny is at the end of last year we took apart one of our broken motors and they are geared down to the slowest speed possible.
John Fogarty
[FTC]: Rhode Rage (FTC 121) is in need of a motor encoder wire Rick FIRST Tech Challenge 2 02-02-2009 01:56
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
[FTC]: Random Error with FTC motor control Xaphiinia FIRST Tech Challenge 2 01-12-2008 15:39
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: [FTC] Motor Controller problems michael714 FIRST Tech Challenge 4 14-10-2008 00:33
