Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 27-10-2009, 17:43
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: 2826 Halonomic Drive Prototype
Clockwise, O contact pattern on the ground, lines are vectors in a clockwise turn, arrows are vertical component of the vector:
\../ (^v)
/..\ (^v)
Clockwise, X contact pattern on the ground, lines are vectors in a clockwise turn, arrows are vertical component of the vector:
/..\ (^v)
\../ (^v)
Eric,
The problem is not with the vertical components of the vectors but rather with the horizontal. Also, I think that what I call "X" and what you call "X" are different.
So, using your notation:
Orientation of torque vectors - Vertical components - Horizontal Components
What I called "O":
/..\ (^v)(>>)
\../ (^v)(<<)
No problem here. The vertical components want the robot to turn CW, and so do the horizontal.
What I called "X":
\../ (^v) (<<)
/..\ (^v) (>>)
Problem! The vertical components want to turn CW, while the horizontal components want to turn CCW. The two cancel each other out as long as the roller friction is negligible.
pic: 1714 Polycarb prototype Crab Drive (backdrop1) xanarchyx Extra Discussion 38 01-11-2009 15:09
pic: 1010 Drive system prototype joeweber Extra Discussion 10 24-08-2009 15:28
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 01-02-2009 02:11
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 13-01-2009 20:42
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
