Re: Using Switches in Autonomus
A pull-(up/down) resistor weakly pulls an input either high or low. This prevents the input from floating around randomly and gives it a "Unless you dictate otherwise, I am high (or low if it is a pull down)." If you've ever had a digital input "flutter" or be otherwise unreliable, you probably needed a pull-___ resistor.
That being said vdubs you might want to let them know that a 10k resistor works perfectly (at least it did for us).
Dont want them to use a small resistor and end up shorting the DS |
I like Alan's recommendation of using a global variable, but why not put the switches on the 'bot instead of the DS?
During the setup time between matches you place your 'bot and set your switches accordingly. We never actually implemented the full code last year, but we had some switches on the 'bot that we could set based on which starting square we were starting in. This way, the Auto code can know its starting position as soon as it starts up. Regrettably, our autonomous code never got that mature and the switches were left unused ... go figure! |
after seeing how other robots are placed.I think our programmer for 2009 even had a one-line autonomous description on the DS box, which was better than a simple number. Not that his descriptions were, well, descriptive. ![]() |
Having the switched on the controls allows for last minute changes to the code in case of a strategy change - dont know how many times we've changed the auton after a brief stroke of inspiration 5 seconds before the match starts.
As for the DS display, I find that showing the position and the begining movement of the robot allows for the operator/driver/coach to identify the auton being used pretty well. For example, one of my codes displays: far left to far right, or center away. |
| Using Limit Switches in LabVIEW | VeedotJaydot | NI LabVIEW | 2 | 14-02-2009 16:01 |
| Toggling boolean using 2 limit switches | Quarkster | NI LabVIEW | 2 | 02-02-2009 22:43 |
| Using Limit Switches with the Arm | iwin2000 | Programming | 3 | 18-02-2008 03:52 |
| Using Switches on the Operator Interface | CronosPrime1 | Programming | 41 | 16-02-2006 11:43 |
| using limit_switch_max/min in autonomus | CmptrGk | Programming | 4 | 11-02-2005 11:32 |
