Go to Post However, the skill of calculating things by hand and sketching by hand is something that we should continue to teach the youth (until my netbook can run Inventor :D) - Zach O [more]
Unread 29-10-2009, 00:29
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
cRIO system watchdog
We have a bench test setup with a cRIO and last year's control system, excluding the driver station, to get experience with PID and motor control feedback.
The reason we're excluding the driver station is because it will be obsolete in two months, and so training people how to use it is not a good use of time.
The problem I'm running into is the PWM, Relay, and Solenoid outputs aren't functioning.
Sounds like the watchdog is dead.
However, I've opened the watchdog and "feed" it more than twice a second using the WPI "Watchdog" VIs (the timeout is .5 seconds).
Perhaps the problem is the system watchdog?
How do you make sure the system watchdog is enabled and active?
-- Marshal Horn
Watchdog!?!?!?! NC GEARS General Forum 38 23-01-2010 08:52
System: Watchdog problems dboisvert C/C++ 7 16-02-2009 02:36
System: Watchdog problems dboisvert C/C++ 1 15-02-2009 20:12
purchasing buying the 2009 NI cRIO control system martin417 FRC Control System 10 29-12-2008 12:31
Nearly Officially Official: cRIO Control System To Be Reused Billfred FRC Control System 64 02-11-2008 20:54
