Go to Post Lets have fun this year - Wayne Doenges [more]
Unread 27-10-2009, 22:03
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
Using a USB switch for an interruptible connection?
Situation: Device A is connected by USB to a USB switch. The switch is connected to Device B. A needs to send information to B, but only after a certain time. For example, A can NOT send information to B for the first 30 seconds, but MUST send information after the first 30 seconds.
No connections can be manually changed or removed.
We are trying to get a button or toggle in place so that A sends information when the state of the button or toggle is changed from false to true.
Any ideas of what to buy or what to jury-rig (and how) to make this possible?
Eschew obfuscation.
"I never enter into a battle of wits with an unarmed person. Therefore, I cannot fight."
Unread 28-10-2009, 11:14
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: Using a USB switch for an interruptible connection?
Without going into the details of how to exactly when to control making the switch(microprocessor choice, etc.), your USB cable consists of 4 wires, +5v, d+(data positive), d-(data negative) and ground. Depending on what device A is, if it has any sort of "bootup" time, you may not want to use the power lines as your "switch". What I would recommend is a DPST relay(something like this) connected to the d+ and d- lines on the USB cable. Then, through your choice of control methods, turn the relay "on" at the end of that initial 30 second period, thereby connecting d+ and d- between devices A and B. You may have to experiment with the timing for when to switch the relay on, as there may be a delay after the devices are connected before they each realize that the other is there.
Hopefully this helps somewhat, I can provide more details if you are interested.
Nate Smith
nsmith@smythsoft.com
Unread 28-10-2009, 13:47
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
It really depends on what data rate you need to support.
Is this a USB 1.0 application or a USB 2.0 application? To maintain a high speed 2.0 application will most likely require an integrated circuit solution, a slower speed application should work fine with a relay as Nate explained.
If you need to go to a high speed integrated circuit solution, Digi-Key has a bunch of chips in the $2.00 range. But they are all surface mount...
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 29-10-2009, 11:48
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
On an aside, thats a beefy relay you got referred to. You may be able to find something cheaper/lighter without a 5 ampere rating.
Unread 29-10-2009, 18:03
AKA: CrazyNate
Yeah, I basically just did a search for DPST relay, and picked one of the first ones that came up...was just meant as an example of what kind you would need, and not a recommendation of that relay in particular.
Nate Smith
Unread 30-10-2009, 07:49
Jeff,
Would a CMOS switch have an application here? Something like a 4053...
Unread 10-11-2009, 19:42
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Thanks for the quick replies, particularly the suggestion to use a relay. We're going in that direction.
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Using a USB Controler Ethulin Control System 8 27-01-2006 21:46
Ideas for using the NI USB-6009 DAQ device Andrew Schuetze National Instruments LabVIEW and Data Acquisition 0 05-01-2006 22:55
USB DAQ Wireless connection? StevenB National Instruments LabVIEW and Data Acquisition 1 01-01-2006 03:49
Using iBooks and a Secure Connection Joe Matt Scouting 8 05-02-2002 21:26
