Go to Post Lighten it up a little to bring it in under the 120 pound weight limit, and I think you will have something there! - dlavery [more]
  #31   Spotlight this post!
Unread 27-10-2009, 19:18
Re: pic: 1714 Polycarb prototype Crab Drive (backdrop1)
Originally Posted by xanarchyx View Post
...o lord not the puns.
So who gets the blame for those? Adam, for getting me started, me for starting them, or team 1714 for building clear robots that we can make puns about?
  #32   Spotlight this post!
Unread 28-10-2009, 12:38
Joining the 900 Meme Team
FRC #0079
Aluminum would be lighter, but the fact that we don't even have a welder makes it a lot harder to work with.
Welding is not a requirement for a competitive FRC robot. I would personally try to learn to work with Aluminum as well as plastics. Both materials have strengths and weaknesses and having more options in your arsenal means you can build the best robot you possibly can.
(And I hope I am not being too transparent about ignoring these puns, they clearly don't add anything to the discussion)
  #33   Spotlight this post!
Unread 28-10-2009, 12:54
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Loving the polycarbonate, it's fun to see a team make a crab module out of something other than the usual aluminum. I'm really interested to see how this holds up after your next modifications are made with the wider belts and everything else you mentioned. I really like the idea of using the belt for both traction purposes and motion. Please keep us posted on your development process as I'd like to see video of your drive system with the usual 130 lbs involved.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
  #34   Spotlight this post!
Unread 28-10-2009, 17:27
Chris is me's Avatar
AKA: Pinecone
While I agree with you for many potential components (I'd think making an AL swerve module would probably be a much safer option), a lot of times for our team there would be little benefit to building the robot out of aluminum when our resources for building that component out of polycarbonate are significantly greater. Take this year's robot, not a single structural failure, and we fabricated the robot faster this way than we would have if we used aluminum. In some cases it's better for our team to use polycarbonate only then. The tricky part is when we come across a game that basically requires a very strong, light part that isn't protected by foam bumpers...
  #35   Spotlight this post!
Unread 28-10-2009, 17:41
FRC #0079
I agree entirely, if you have better resources for working with a material and a part can be made out of that material without impacting its performance then by all means make it out of that material. I was merely remarking on a general concept that I see too often, people assume that one material is "better" than another. For example, a lot of times people will assume metal > wood. This is wrong, metal > wood in some applications in others the converse is true. In engineering, as in life, everything is a tradeoff. For example this component, while making it out of Aluminum may be safer and lighter (may or may not be the case but this is just an example so it doesn't really matter) you can fabricate the Polycarb easier. Which one you decide is based on certain criteria. As I said, just a general statement geared more towards a general audience than your specific design.
I do like the fact that you guys are finding limits of polycarb with PolyCrab. I just would like to see how it holds up compared to Aluminum. Perhaps do some tests (either in CAD or on the actual thing) to see how it holds up. This is the off season, why not take the time to find where you can cut weight out or where you need more material?
  #36   Spotlight this post!
Unread 29-10-2009, 14:50
Aren_Hill's Avatar
Build Nifty Things
questions
1. How big is that lower pulley?
2. What diameter is that lower disc
niftyness
A guy who likes robots.
  #37   Spotlight this post!
Unread 30-10-2009, 10:49
xanarchyx xanarchyx is offline
Capt' of Manipulator
AKA: Collin Matthews
FRC #1714 (More Robotics)
xanarchyx is an unknown quantity at this point
pully = ~ 7/8 (real one will be a bit bigger)
disk = ~ 3in
  #38   Spotlight this post!
Unread 30-10-2009, 11:31
Aren_Hill's Avatar
Build Nifty Things
disk = ~ 3in
by "lower pulley" i meant what your using as a wheel
by "bottom disc" i meant the side support disc diameter
  #39   Spotlight this post!
Unread 01-11-2009, 15:09
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
The lower pulley is roughly 3in, and the bottom disc is 5.5in.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
pic: Crab Drive Prototype Weekend Build Alex698 Extra Discussion 9 13-01-2009 20:42
pic: 1771 crab drive sdcantrell56 Extra Discussion 9 29-06-2008 00:02
pic: A closup view of our prototype worm-crab drive system. AndyB Extra Discussion 6 20-01-2008 00:02
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
