Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 01-11-2009, 18:56
MattSr's Avatar
MattSr MattSr is offline
Mentor/Programmer/Animator
AKA: Matt Cyril Senior
FRC #0488 (Team Xbot)
MattSr is an unknown quantity at this point
Send a message via AIM to MattSr Send a message via MSN to MattSr Send a message via Yahoo to MattSr
[FTC]: Issue with POV on LabVIEW "FTC Read Controler.vi"
While working on programming my team's robot one day, I noticed that there was no POV output for the "FTC Read Controller.vi" block. I looked into the block a little and found out that the block supports the POV, it's just that whoever made the block, forgot to set up the POV's output node. There is a fast and easy fix for this for those who don't know how:
1) Place an "FTC Read Controller.vi" block if you don't already have one
2) Double click it
3) Scroll to the left a bit until you see the POV's output way off to the side
4) Right click on the VI's icon in the top right corner of the window and press "Show Connector"
5) Click one of the empty white squares, then click the POV's output you found earlier (I like to use the bottom right
6) Save and close the VI
7) All your programs on the specific computer that you open should be updated with the change you just made
You will have to do this once each time on each computer that you have LabVIEW installed on
Much love to my favorite FRC teams:
1983 Skunkworks - 360 The Revolution - 2898 Flying Hegehogs - 2557 Sota Bots - 2942 Tech Robotics
[FTC]: Bluetooth Problem with LabView/FTC Controller Station James Dowd FIRST Tech Challenge 8 27-10-2009 10:40
[FTC]: LabView servo issue Abra Cadabra IV FIRST Tech Challenge 1 02-02-2009 13:44
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
