Go to Post If you speak three languages, you're trilingual. If you speak two languages, you're bilingual. And if you speak one language, you're American. - Hieb [more]
Unread 02-11-2009, 10:41
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Re: pic: 955 T-Shirt Bot @ Halftime
Originally Posted by Andrew Schreiber View Post
What was drawing so much energy?
Inside there are five kit compressors and four CIMs driving AM 6" mecanums through Banebots 12:1 planetary transmitions. All of the compressors are powered by one battery and the drive, elevation, and controller are powered by the other.
The issue is trying to run the compressors over an extended amount of time. We can fire about three shots at max pressure before the battery is drained. The other issue we didn't plan for was firing when our team scored, it is unpredictable at best and holding pressure for long periods of time means the compressors tend to be "topping off" constantly. Either getting a battery better suited to the job or having a setup where we can keep it plugged in most of the time are the options we are considering.
The other slight issue is that fact that the robot weighs about 275 lbs. It is taxing our drive as is and we are considering changing our gear ratio to 16:1. Adding excessive weight at this point wouldn't help us be mobile
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
FIRSTcast: Season 4 Episode 7 - Halftime Jeff Rodriguez General Forum 0 27-01-2009 12:55
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
Team 955 Karma Website Design/Showcase 7 25-02-2005 01:22
Team 955 Animation Storyboard Li Jianliang 3D Animation and Competition 0 13-02-2005 16:01
Congrats to 254, 1425, 753, and 955 Nate Edwards Thanks and/or Congrats 2 21-03-2004 18:13
