Go to Post YES!!!!!! I read this and jumped! This is awesome and amazing! Thank you so much Dean Kamen and FIRST!!! YOU ARE AMAZING! - torihoelscher [more]
Unread 02-11-2009, 23:12
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Multiple Gyros
Our team is working on a project requiring multiple gyros. In LabVIEW, when we create the open gyro block, the options for the slot and channel only allow us to select channel 1 or 2, only allowing the use of no more than two gyros. Is there a way around this? Does this have anything to do with the FPGA?
Eric
Unread 03-11-2009, 00:01
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Multiple Gyros
Eric
The FPGA only has 2 accumulator channels.
In order to get an average heading from a gyro, you need to continuously integrate your readings, and that is what the FPGA accumulator is doing.
You could do your integration in your main loop, but there is no guarantee of having a steady integration time, your dt.
Though, i have to ask, what are you going to do with more then 2 gyros?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 03-11-2009, 01:00
Re: Multiple Gyros
I agree with everything Biojae said in that last post.
If you just want rate, not heading, you can just open the gyros as analog channels and do the conversion manually.
If you need heading information, you may be able to hack something together that is slightly better than what biojae was alluding to. However, it is not for the faint of heart. I was working on combining the oversampling engine with the dma engine to create a fake accumulator. Basically, the oversampling sums up N samples and the DMA deterministically sends them up to the processor. Then when you integrated in software you'd have all of the samples accounted for exactly once. I never got it to work fantastically, maybe you'll have more luck.
Enjoy!
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
Gyros EROCK Kit & Additional Hardware 10 21-01-2008 18:58
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
Gyros!! RAWdealer59 Programming 1 12-02-2003 16:46
gyros archiver 2001 6 24-06-2002 02:35
