Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 03-11-2009, 00:01
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Multiple Gyros
Originally Posted by ebmonon36 View Post
Our team is working on a project requiring multiple gyros. In LabVIEW, when we create the open gyro block, the options for the slot and channel only allow us to select channel 1 or 2, only allowing the use of no more than two gyros. Is there a way around this? Does this have anything to do with the FPGA?
Eric
The FPGA only has 2 accumulator channels.
In order to get an average heading from a gyro, you need to continuously integrate your readings, and that is what the FPGA accumulator is doing.
You could do your integration in your main loop, but there is no guarantee of having a steady integration time, your dt.
Though, i have to ask, what are you going to do with more then 2 gyros?
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
Gyros EROCK Kit & Additional Hardware 10 21-01-2008 18:58
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
Gyros!! RAWdealer59 Programming 1 12-02-2003 16:46
gyros archiver 2001 6 24-06-2002 02:35
