Go to Post I want to understand the physics. - Molten [more]
Unread 03-11-2009, 17:53
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
NXT SERVO CONTROLING SPEED CONTROLER
We are trying to incorporate the NXT into other uses and want to use the NXT Servos to control some speed controllers. We have gotten it kind of working. When we push forward we cant just hold down the controller forward. We have to step it forward, one push at a time, almost like a button. then when we want to go backward we have to step it all the way back down to stop then step it further backward for reverse. We would like it to be a smooth transition for forward and reverse, similar to using the speed controller that came witht he NXT. Any ideas?
Michael
Stampede Robotics Mentor
FRC 2844
2012 Arizona Regional --Judges' Award
2012 Las Vegas Regional -- Regional Winners
2012 Las Vegas Regional-- Coopertition Award
2009 Arizona Regional -- Rookie All Star Award
Unread 03-11-2009, 18:54
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Re: NXT SERVO CONTROLING SPEED CONTROLER
I suspect the NXT motor's encoder doesn't give you absolute position of the axle. Just like any other optical encoder it's up to software to convert the encoder signals into absolute location. A typical encoder will give you a direction signal and a pulse every time the shaft has rotated x degrees.
I don't know the details of the software you're using so you're on your own there. If this is for FTC RobotC might well do some of this for you.
Unread 04-11-2009, 13:19
mjgard's Avatar
Michael
AKA: Michael Gard
We are using labview and the 2008 FTC Template code to run the servos, then using the PWM outputs of the servos, connected to a speed controller.
Michael
FRC 2844
Unread 04-11-2009, 14:17
I think there might be a terminology problem that's keeping people from understanding what you are trying to do. Servos I am familiar with don't have PWM outputs; they have PWM inputs. If you want to connect a speed controller, you should not also connect a servo.
Unread 04-11-2009, 14:28
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
Also on the terminology front, the NXT's motors aren't servos, they're just motors with encoders built in. They run on an I2C interface.
Unread 04-11-2009, 15:25
mjgard's Avatar
Michael
AKA: Michael Gard
Ok I understand the confusion. We are using the NXT with the Servo Controller for Tetrix. The servo controller has a pwm output. We are using the output from the Servo controller and putting that as the input on other speed controllers. The speed controllers are powered independently from a 12v supply. We are doing this because we believe the motors we are trying to power are to large for the hitechnic motor controller.
Did that clear up what we are doing?
Michael
FRC 2844
NXT - 884 Speed Controllers team63 Motors 2 05-09-2008 11:26
controling extension on piston m1k3 Pneumatics 16 14-01-2008 16:04
Direct control of a Servo or Speed Controller Schmitty! National Instruments LabVIEW and Data Acquisition 3 06-03-2006 13:53
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
Controling Pneumatics archiver 2001 14 23-06-2002 22:44
