Go to Post There is nothing wrong with being great and being proud of it. - TubaMorg [more]
Unread 04-11-2009, 20:34
Richard100 Richard100 is offline
FRC #0836 (RoboBees)
Richard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to behold
Need FRC Toolkit for LabVIEW
Does anyone know where to download the toolkit for FRC? By 'toolkit' I mean the library of programming VIs for the FRC hardware - encoders, gyro, etc. We've lost ours. If they cannot be downloaded, could someone send us the file(s)?
Thanx,
Team 836 / RoboBees
Southern Maryland
Unread 04-11-2009, 22:12
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Need FRC Toolkit for LabVIEW
Do you have your original DVD's? Follow the instructions here: http://decibel.ni.com/content/docs/DOC-2877 including installing the 3.0a update. The FRC library is in the vi.lib subdirectory in the Robotics Library subdirectory.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 05-11-2009, 07:13
The disks are gone. We were using LabView 8.5 last year, I believe. We still have that loaded on a team laptop - maybe there's a way to transfer the toolkit to another computer?
The school training computers have been loaded with LabVIEW 2009 .. will last year's toolkit work with the 2009 version?
Unread 05-11-2009, 08:21
Not entirely. The VIs from LV8.5 will load, but you likely don't have all the toolkits installed such as LabVIEW runtime, and additionally, you'd need to transfer over the WPILib VIs, which could be done.
If you were to take over the VIs and WPILib you will probably be able to open and edit them, but not run them on the cRIO. Then there is also the issue of taking them back to LV 8.5 or 8.6. For that, you'd use the Save for Previous feature in LV.
This is doable, but it'll be much easier to borrow the DVD from another team or find the one from last year.
Greg McKaskle
Unread 08-11-2009, 19:46
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Greg McKaskle
Greg,
Can you ellaborate on what exactly is necessary to deploy a project using LabVIEW 2009 to an FRC-cRIO?
Thanks!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 09-11-2009, 21:17
As I said in my earlier post, I'm not sure if it will run.
You will be able to load LV 8.5 VIs into LV 2009, but you will either need to ignore the missing VIs or move them over from 8.5. To add them, copy the vi.lib/FRC and place it in the LV 2009 version of vi.lib.
I suspect this will let you load with few if any errors. The remaining error if there is one will likely be RIO related.
To run the project in 2009, you'll definitely need LV Realtime installed and you'll need compatible versions of Visa and RIO drivers. I'm not sure if the 8.5 drivers will work with LV 2009.
If this does run, please post letting me and others know.
Greg McKaskle
Unread 13-11-2009, 12:14
Manoel's Avatar
Greg McKaskle
Greg,
Apparently it will not work. I installed LabVIEW 2009 with the Realtime toolkit and drivers and all, as an evaluation version, and tried to open an example VI (Motor Control, I believe) from LV 8.5. After locating all the missing VIs, it would not run. Apparently the FPGA libraries are changed, so there are lots of error about connector panes with missing wires and wrong data types. Since the FPGA VIs used in FRC are password protected, I can't even take a peek at the block diagram to see if it's easily fixable.
Care to jump to this old thread and help me out with that old problem I had?
Brazilian Machine
Team # 383
Need Help: FRC Labview with local USB-cam (or laptop Webcam) Ziaholic NI LabVIEW 6 21-09-2009 16:43
need ftc toolkit j27 NI LabVIEW 1 22-07-2009 15:26
LabVIEW Training for FRC Teams Danny Diaz National Instruments LabVIEW and Data Acquisition 8 23-07-2008 10:24
LabView FRC Toolkit code level issue KHall National Instruments LabVIEW and Data Acquisition 2 11-06-2008 10:40
Serial Communication Problems with LabVIEW FRC Toolkit Jon236 LabView and Data Acquisition 1 28-12-2006 11:57
