Go to Post Oh, and your t-square and pencil can't crash, unlike your laptop :D - scottydoh [more]
Unread 05-11-2009, 09:33
May_Walter's Avatar
May_Walter May_Walter is offline
Artemis #3083
FRC #3083 (Artemis)
May_Walter is an unknown quantity at this point
Smile A few questions
Hello Everybody
We have a few questions that we wood like to ask you, and we will appreciate your help at those issues.
The first one is regarding the position of the battery while we are charging or storing it. Is it allowed to place it horizontally?
The second is regarding to the crate. We wood like to change it to a multifunctional crate, which will combine the crate for shipping the robot and also a tool shed. We need to know, it is even allowed? And also, what are its measurements?
The final, are we allowed to use more then one camera?
Thank you in advance,
Team Artemis #3083, Israel.
Team ARTEMIS - #3083 - The Sky Isn't The Limit Anymore!
2011- FRC Team Captain and Coach, FLL mentor & Ref. Semi-Finalists, Motorola Quality Award, Star of the Day.
2010 - FRC Team Captain and Coach, Engineering Inspiration Award, UL Industrial Safety Award
2009 - Coach, Judges Award, Finalists w/ 3075 & 1690
Unread 05-11-2009, 09:43
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: A few questions
HELLO!
An answer to some of your questions-
1. Batteries can be charged and stored horizontally. We have a charging station in which the batteries are slide under the chargers. Just note that when horizontal, the terminals will have a larger chance of getting smacked around/damaged. We store ours vertical but whatever works out for you.
2. Multifunctional crates are allowed, but don't go making your crate just yet, FIRST most likely is going to change the size of them for this upcoming year so waiting until kickoff to build your crate would be a good idea. More info on the crates can be found here- http://usfirst.org/roboticsprograms/...70&terms=crate
1058 PVC Pirates 2016 - xxxx
Unread 05-11-2009, 10:37
Joining the 900 Meme Team
FRC #0079
Re: A few questions
Originally Posted by BrendanB View Post
HELLO!
Not to try to confuse you but this needs a disclaimer, Rules from previous years may not apply in the future.
In the past battery orientation has not mattered, I can't see this changing but there is the possibility of it changing.
The common theory is that Crate rules will be changing, it may be wise to hold off on actually building a crate until we know for certain. Until that time though, design away.
As for the camera, the prior statement applies here. You best bet would be to wait until the robot rules come out and then check there. If there is confusion after that feel free to use the official Q&A. However, if you happen to have two cameras at the moment and would like to learn with them in the off season no one will stop you.
Unread 05-11-2009, 10:46
AKA: Brendan Browne
Re: A few questions
Andrew, you're right, I should have included a disclaimer. Walter like Andrew said, rules change a lot from year to year. Never plan too much ahead for the upcoming season as no one (except an elite few) know what the game and rules are.
**DISCLAIMER**-statements in post two are subject to change by FIRST representatives following the kickoff date of January 9, 2010. Be advised that prior rules will not apply following said date.
Unread 05-11-2009, 11:30
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: A few questions
Originally Posted by May_Walter View Post
Hello Everybody
I'll take a shot at answering these:
1> The rules over the last few years have been silent on this, therefore have been able to orientate your battery as needed. This may or may not be true after kickoff when we get new rules.
2> Many teams have used their crate as part of their pit setup. Search crate here on CD to find some of the designs. That said, Bills blog has indicated that there may/will be changes to the shipping/crate rules ... proceed here at your own risk.
3> There have not been any rules in the past about multiple cameras, although that is subject to change at kickoff, but the camera driver used last year looked at a specifia address, making it difficult to use 2 cameras.
___________________
- Tennyson, Ulysses
Unread 05-11-2009, 11:45
Re: A few questions
The allowed cRIO connections last year made using two Axis cameras impossible. There just wasn't anywhere to wire another one to. That might change next year, or it might not. It wasn't a technical issue, just a legal one.
The single fixed address was a technical issue, and it looks like it will change next year. The 2010 Beta LabVIEW libraries have the IP address specified as part of the camera setup. It would be interesting to see if the system can talk to multiple cameras at the same time.
Unread 05-11-2009, 11:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: A few questions
Charging and storing the batteries horizontally is fine, charging or storing upside down is the only orientation not recommended.
A few questions Magnechu Rules/Strategy 8 25-01-2008 17:01
Few questions rohit Inventor 5 07-03-2007 09:07
A few questions Chase General Forum 15 14-08-2005 13:29
A few questions cheezewiz Programming 7 31-01-2004 00:02
A few questions goegan31 Regional Competitions 1 09-03-2003 20:32
