Go to Post The FIRST World has your back. - MishraArtificer [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 06-11-2009, 09:39
3758 3758 is offline
FTC #3758
3758 is an unknown quantity at this point
Acrylic Sheets
Hi,
My team was wondering whether we could use Acrylite Acylic sheets on the robot. I found that Lexan and Acrylite were both thermoplastic sheets, but I was just posting here just to be sure.
Unread 06-11-2009, 09:59
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Acrylic Sheets
I would never use acrylic on my robots. It's impact resistance is just not up to the abuse. I don't even allow it in the lab so it isn't mistakenly used on the robot.
Stick with polycarbonate (lexan.)
Unread 06-11-2009, 10:06
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
wilmo will become famous soon enough
Re: Acrylic Sheets
Seconded. Lexan can defiantly take much more abuse than the acrylic sheets. Lexan can take a full bore robot collision with minor damage while acrylic can be easily cracked if you even try to drill into it.
Unread 06-11-2009, 10:07
Re: Acrylic Sheets
Are you asking about FTC or FRC?
Unread 06-11-2009, 10:26
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Acrylic Sheets
Stick with Lexan as everyone has suggested. Just a note in forming it. If you "heat soak" it for a while at below thermoform temp, you force out trapped vapor, and eliminate bubbling in the sheet that occurs if it is heated too fast. Experiment and it's appearance will be maintained.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 08-11-2009, 11:40
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: Acrylic Sheets
I vote for polycarb, over acrylic. No matter where it's used.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 08-11-2009, 16:56
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: Acrylic Sheets
FRC rules do not allow acrylic (Plexiglass (tm)). Stick with polycarbonate (Lexan (tm)) as it is impact resistant.
Unread 08-11-2009, 17:04
Joining the 900 Meme Team
FRC #0079
Re: Acrylic Sheets
What rule (from last year) forbids it?)
Also, he isn't in FRC, he is in FTC. Different rules.
Unread 08-11-2009, 23:11
Chris is me's Avatar
AKA: Pinecone
Re: Acrylic Sheets
FTC rules do not allow acrylic (Plexiglass (tm)).
Fixed.
For either program, acrylic should never be used, except for some really obscure exception or something. Always always use polycarbonate.
Unread 08-11-2009, 23:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Acrylic Sheets
in FRC you could almost build your whole robot from polycarbonate...right?
Unread 09-11-2009, 16:42
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Acrylic Sheets
I can think of more than a few roles where acrylic would be suitably strong, such as concealed ball hoppers/dividers or decal backing. Just never use it for anything structural or might otherwise take any shock loads.
Unread 09-11-2009, 20:16
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: Acrylic Sheets
They're really close in price though, if I remember correctly, so wouldn't you go for polycarbonate just because it won't shatter on you?
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 09-11-2009, 22:06
IndySam's Avatar
Re: Acrylic Sheets
We have had decal backing shattered by another robot. Shards of plastic in your robot can be bad.
Polycarb is generally twice as expensive as acrylic.
Unread 10-11-2009, 22:06
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
Re: Acrylic Sheets
Funny that you say that, especially since you built a crab drive structure out of the stuff.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Unread 11-11-2009, 00:01
AKA: Pinecone
Re: Acrylic Sheets
That's just for prototyping a few plates that need to be milled out of poly that are harder to machine. The piece of acrylic is being used as a place holder.
Any "real" crab module will have zero acrylic in it, and I'm hoping my team's replacing the temporarily acrylic parts of the prototype rather than waiting for competition to build one that's strength testable...
Fact sheets? asmo0901 General Forum 12 06-04-2009 18:10
Scouting Sheets drhall General Forum 17 03-04-2009 13:35
Acrylic Gearbox Sideplates AndyB Technical Discussion 20 21-07-2008 19:42
Scouting sheets SoccerNerd36 Scouting 6 24-01-2005 19:27
scouting sheets DLyons Scouting 1 14-02-2003 13:05
