Go to Post What is this "off season" of which you speak? - Alan Anderson [more]
Unread 11-11-2009, 11:36
crollison crollison is online now
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
[FTC]: Labview - Servos
Second year in FTC, last year did all programming in NXT - easy to learn, just not functional enough. Now trying to work in Labview, got to get it figured out to teach my students enough to get going.
I can't find enough good examples for labview to help. I'm stuck trying to figure out how to program the servos to be controlled with either the joystick or buttons. I can figure out how to go to a specific point if a button is pressed, but if I wanted to hold button down to move one way.
If anybody could send me a screen shot or sample program it would help greatly. Getting short on time. Working in most recent version of Labview.
Thanks.
Unread 11-11-2009, 13:47
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: [FTC]: Labview - Servos
I created a simple VI that shows you one way to accomplish this. I leave it to your to modify it so it fits into the templates.
http://www.chiefdelphi.com/forums/at...d=125796519 7
You can add this VI to your block diagram by saving the image to disk and dragging the image file into your block diagram
Name:	open and close servo.png
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 13-11-2009, 10:38
AKA: Chris Rollison
Thank You very much, that helped a lot.
[FTC]: Bluetooth Problem with LabView/FTC Controller Station James Dowd FIRST Tech Challenge 8 27-10-2009 10:40
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
Labview Servos quizbiz NI LabVIEW 5 09-01-2009 08:48
[FTC]: [FTC]: Can any one explain to me just how powerful the servos are? sullivan_owns FIRST Tech Challenge 19 02-12-2008 16:06
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
