Go to Post Your wheels look delicious. - Alexa Stott [more]
Unread 11-11-2009, 06:38
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: [FTC]: How far is everyone?
Originally Posted by BradMello View Post
If only we could see the robot XD, nice work though
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 11-11-2009, 09:19
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We have our shooter completed and a working drivebase. Auto-mode is coming along. We still need to work on the pickup system and storage. That's still a TON to do before Dec 12...
The shooter can throw a ball ~9 ft right now. It's our 5th generation and the first one that works. I'll see if I can't post a pic/video or three after our practice tonight.
Unread 11-11-2009, 09:40
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
2 out of 4 of ours look like a robot! It seems slower going than usual, but that's because they're taking the time to do quality work the first time and unit test each subsystem so there are fewer "integration" issues and less "speedy build" at the end. So the perceived slow going is probably further along that any other year. The 3rd bot has alot of plastic forming to get correct, but it should be good to go once some parts come in, and the 4th team ... well ... maybe they can play defense? They're still "designing" with only a drive train physically built ><. Seems like a harsh thing to say, but this late into build it's time to face some sort of reality.
An interesting thing to note is the height of the spin bar -- the bar is 10" off the ground, at least it is on the field we built. Anyone else notice that? It's also 10" away from the center-area wall in most spots, so spinning it requires going in the middle, violating a rule, or pushing the design limits. Interesting indeed.
2017 Scoring Model
CAD Library | GitHub
Unread 11-11-2009, 16:07
Chris is me's Avatar
AKA: Pinecone
My potentially flawed interpretation of the rules says you can be in the center field structure all you want as long as you're not touching the High Goals or blocking points from being scored into them. There is no penalty for being in the low goal at all. There are wood blocks your robot has to climb to spin the bar a significant distance, though.
Unread 11-11-2009, 16:32
JesseK's Avatar
FRC #1885 (ILITE)
You're correct in your interpretation of the rules, though I think that the middle is a death trap. If you can climb the wall, you can climb a ball. If you climb a ball at the wrong time and are too big ... your bot will hit the high goal an inur penalties. Though that's just my synopsis of it though, and it may play out completely different. Our strategies make the assumption that we'll never need to go into the middle and that if we may miss the middle we'll save the shot for the outside ... meaning we'll never miss and therefore never need to go into the middle to retrieve. At least that's the theory, though teams may very well incur 40pts of penalties just to make us miss 10+ balls.
2017 Scoring Model
Unread 11-11-2009, 16:42
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
In my opinion you should be able to climb the goal and block points from being scored and then move around a little and get out, I don't think going over balls will be as big a problem as you anticipate because if you take it slow going in you should me the balls out of your way then be able to back up the way you came in, if need be, to get out
Unread 11-11-2009, 16:52
AKA: Pinecone
Blocking points (other than through robot collision / goal motion) is a penalty this year, so be careful with robot designs and height.
Unread 11-11-2009, 18:49
jamie_1930's Avatar
Team Role: Student
What I mean is that if your inside the low goal you've drastically reduced the scoring area available. At competition this may come to the referees interpretation of the rules, in my opinion since some may consider it not in the spirit of FIRST that it will be changed soon after it's first tried.
Unread 11-11-2009, 18:52
The rules of a game should reflect the value of its creators. If this strategy is "not in the spirit" of the game, the rules should not allow it. Executing a legal strategy is never wrong.
Unread 11-11-2009, 19:30
AKA: @doctorfogarty
LAWL we completly veered of the topic of this forumn XD but it tis intresting.
John Fogarty
[FTC]: How do you find new FTC team members? NalaTI FIRST Tech Challenge 3 26-07-2009 10:50
[FTC]: [FTC]: Can any one explain to me just how powerful the servos are? sullivan_owns FIRST Tech Challenge 19 02-12-2008 16:06
[FTC]: IMPORTANT EVERYONE READ!!! FAULTY PARTS!!! qwertyuiop[]\ FIRST Tech Challenge 3 23-10-2008 16:58
How far are you? Duke 13370 Robot Showcase 0 31-01-2003 21:01
How far is everyone in their autonomous programming AlphaOmega870 Programming 33 21-01-2003 21:03
