Go to Post Realizing your DON'T want to be an engineer is every bit as important as realizing you do - Lil' Lavery [more]
Unread 14-11-2009, 17:24
blackiceskier's Avatar
blackiceskier blackiceskier is offline
ziggy!!!
AKA: josh T
FTC #3041 (URSA MAJOR)
blackiceskier will become famous soon enoughblackiceskier will become famous soon enough
Send a message via AIM to blackiceskier
selling supplies
our team had an awesome idea and we wanted to know what the world of CD thinks of it.
have you ever ran into the problem of not having a part that you really need or you can not find a team to loan you one either. well what do you think about having first or vex competiton committie runners have a place to buy a quick spare part that is a total necessity. there is already this set up at larger competitions like worlds but what about the smaller regionals where it is needed more
Unread 14-11-2009, 17:31
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: selling supplies
Part of what is sent to each event is a spare part table, it has some standard parts and is rarely varied between regionals. Information about it is usually put out in one of the last updates.
- Arizona North
Unread 14-11-2009, 18:03
NickE's Avatar
NickE NickE is offline
_
Is this the same between FTC and FRC?
Unread 14-11-2009, 18:25
AKA: Alex Tannahill
I do not know about FTC.
- Arizona North
Unread 14-11-2009, 18:37
NickE's Avatar
_
I'm guessing that the original poster was wondering in regards to FTC, due to his posted team being a FTC team.
If this is true, should this be moved by a moderator to the FTC forum?
Unread 14-11-2009, 22:01
To quote Billfred from some time ago,
"At the same time, not having particularly scarce COTS parts you put on the robot would be a bad call as well. Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three."
If you have a given part that is that critical, you should have spares if you might need them--or if you probably won't, due to Murphy's Law.
Aluminum Stock Supplies? BurtGummer General Forum 11 06-04-2009 06:48
Turret Supplies? Andrew Blair Technical Discussion 2 15-01-2006 21:20
Common team supplies halomaster69 Chit-Chat 9 03-03-2005 02:54
Button supplies archiver 2001 7 24-06-2002 01:50
Portable 12V Power Supplies? archiver 2000 2 24-06-2002 00:19
