| View Poll Results: What are your team's current robot capabilities | |||
| None |
3 | 13.04% |
| Can Hord Balls |
15 | 65.22% |
| Can Score in Low Goal |
10 | 43.48% |
| Can Score in High Goal |
16 | 69.57% |
| Can Score in Four Foot Goal |
17 | 73.91% |
| Can Open Ball Shoots |
18 | 78.26% |
| Multiple Choice Poll. Voters: 23. You may not vote on this poll | |||
#9
[quote=
I honestly think the 10 point goal is the most important part of the game. Scoring in it is just as valuable as scoring in autonomous, but easier as you have drivers to control it. The goals are also wider so you can shoot 2 or 3 balls wide into the goal, unloading at ridiculous speeds. Just one corner worth of balls plus a doubler and your preload and you break 400 points. 40 point penalty doesn't look so bad now.[/QUOTE] Ok if you go for the spin bar, then by the time you get there the other robot has the 40 points. IF they can get in range and gets them in right away. THEN its like they have 80 points (I don't think its the best way to win) + they only get 40 points if they get all 8 balls in with alto mode UNLESS they get the YELLOW ball in at the end. ![]() |
| Capabilities of a Hall-Effect sensor | Michael Hill | Electrical | 15 | 28-08-2008 15:09 |
| Tetra Stacking Capabilities | SoccerNerd36 | Rules/Strategy | 3 | 06-03-2005 10:21 |
| Team 95 Bot capabilities, take a look. | archiver | 2001 | 3 | 24-06-2002 01:53 |
| Aluminum Weld capabilities at Zeeland? | archiver | 2000 | 0 | 23-06-2002 23:01 |
| T-Rx pictures and capabilities | Rick Gibbs | Robot Showcase | 0 | 23-02-2002 22:26 |
