| View Poll Results: What are your team's current robot capabilities | |||
| None |
3 | 13.04% |
| Can Hord Balls |
15 | 65.22% |
| Can Score in Low Goal |
10 | 43.48% |
| Can Score in High Goal |
16 | 69.57% |
| Can Score in Four Foot Goal |
17 | 73.91% |
| Can Open Ball Shoots |
18 | 78.26% |
| Multiple Choice Poll. Voters: 23. You may not vote on this poll | |||
#16
Re: [FTC]: Robot Capabilities
It helps because otherwise it'd be (effectively) 0 blue, 40 + 40 = 80 red.
#17
no unless you and your partner cant shoot them in the 5 point goll then it would be like that IF the other team get all 8 in the 5 point goll in ayto mode and if they get the yellow ball in also,but you do whatever i just think it would'nt be that smart to do it.
#18
o and every time you hit the spin bar you - 40 points so if you bump it 2 times you get -80 points
#19
You get points for balls in autonomous, then you get points again at the end of the game. No doubler ball needed. Essentially all balls scored in auto are worth double points. |
#21
ok, great now do you know that its not a smart thing to do (most of the time)
#22
We reconfigured our loader 100% more efficiant!!, hahaaa i'm gonna post a vid. I'll give you a hint popcorn machine XD
#23
It's because the balls are counted at the end of auton -- N balls Plus whatever was scored during teleop - M balls thus the point values are 5*[N + (N+M)*2] or 5*[2N + N + 2M] = 5*[3N + 2M] -- thus since N represents autonomous balls, they're worth 5*3, or 15 points each with the double ball, meaning it's still worth it to do auto and get the ball. This makes for some very interesting math when making strategies, where impulse decisions can definitely cost you some points. |
#24
In any case with a sufficient amount of balls in during autonomous, all an alliance has to do is block opponents' bonus ball chutes and/or outer goal shots during endgame. Ball for ball without bonus, auton balls are worth just as much as outer goal balls. Since the alliance who scored only autonomously would be ahead in quantity at the start of endgame, they can afford to use both alliance robots for effective defense in order to win. Perhaps you could let them score a little to up your QP, but that's somewhat difficult to do yet also guarantee a win. Personally I'd rather guarantee the win. |
#26
This is all speaking theoretically since I don't have an FTC team this year, though if you could have a "blocker for the blocker" who scored in auto as a teammate perhaps it would work better. If you can score big chunks of points very quickly, letting up on the defense for 3 to 5 seconds could get a few hundred points. Smart defense could potentially spin you into shooting for your opponent's goal though. :/
I still want to see an all 10 point mega fast shooter, but it certainly looks more beatable now. I'd still build a robot primarily designed for it at this point. |
#27
If you score all of your points in autonomous and then rely on blocking the bonus ball chutes, you lose. You lose because you give up your ability to get the bonus ball and allow your opponents uncontested shots at the outer goal means that a robot specifically designed for hoarding and firing at the off the field goals should still be able to outscore what you've done in autonomous (and to a lesser extent, the teleop).
#28
if you relly want to spin it with out geting -40, aim at the goll and shoot at it and it will spin
#29
from what i saw you guys didnt do anthing in autonomous
#30
The reason we didn't score in auto mode is because are opponents can pull the ball shoot beside us, so we had tech brick do auto mode so there's no way our ball shoot will pulled ,what im saying is that we can score in auto mode but we didnt want the ball shoot pulled before we get to it in driver control.
| Capabilities of a Hall-Effect sensor | Michael Hill | Electrical | 15 | 28-08-2008 15:09 |
| Tetra Stacking Capabilities | SoccerNerd36 | Rules/Strategy | 3 | 06-03-2005 10:21 |
| Team 95 Bot capabilities, take a look. | archiver | 2001 | 3 | 24-06-2002 01:53 |
| Aluminum Weld capabilities at Zeeland? | archiver | 2000 | 0 | 23-06-2002 23:01 |
| T-Rx pictures and capabilities | Rick Gibbs | Robot Showcase | 0 | 23-02-2002 22:26 |
