Go to Post TIME is the one commodity you cannot buy more of. - Andy Brockway [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 10-11-2009, 04:00
Chris is me's Avatar
AKA: Pinecone
CMS solutions for team website?
I've been meaning to make an easy to update and manage 1714 site using Wordpress as a CMS, as for years we've used raw FrontPage html that generally looks pretty bad. Of course, now that I have better things to do with my time I really want to have another go at it. Funny how that works out. WordPress is simple to set up, but as it's designed around blogging, a little bit difficult to work with, and is generally not very conducive to page based formatting.
Anyone know of any good, free content management systems for web sites that allow for server side editing (i.e. you could log in from any computer from the internet and easily modify site content, with some kind of bbcode / wysiwyg editor)? Unless the team gained someone very proficient in web design that I don't know about, this seems like the best way to have an up to date team site.
Thanks in advance!
Unread 10-11-2009, 04:02
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: CMS solutions for team website?
1745 uses and loves joomla. its easy to install easy to use, and lots of addons.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 10-11-2009, 09:19
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Wordpress should work fine as long as you are centering the design/theme around pages instead of posts. (http://theunstandard.5thirtyone.com/ is an epic "CMS-tailored" theme)
Team 2502 has been using Homebrewed Wiki System+punBB. It was very good (we themed our wiki to look exactly like punBB.) We were able to easily make and modify pages. Real easy. So using a wiki system is an option. If you decide to do that, you should really hook up with AdamBots. Like as a designer myself, I puke at a lot of team's websites, but AdamBots is one that I have an orgasm at. (Figuratively). One problem with this is there was not a good communication tool for email blasts/reminders/etc.
Our second year, we had a refresh. We got ExpressionEngine and the forum plugin. It was very powerful, but too powerful and too extensive for our easy-to-maintain needs. Also, the framework in which we built the new site didn't fit the ExpressionEngine's model too well and we had to do quite a bit of hacking around to get things working.
Our third year, this coming season, we have set up a Ruby on Rails server and we're running the RadiantCMS. It's very ubiquitous. It has a large developer base and plugins. For instance, I can hook up all members from Radiant to the Beast forum software on Ruby on Rails. It has page versioning, etc. It's VERY simple. It has Layouts, Snippets, and Pages. Layouts are for the schema of the output document (so here, you can design your page as an RSS page, HTML page layout with 1 column/2column/etc, even a vcard. You get to type in the page structure. Then in snippets you can put stuff like menus/footers where it gets repeated a ton throughout every html page. Then in pages, you worry about nothing but content. This site is being rapidly designed. It took me a while to initially figure out how I was going to put the whole site together, then after that it was real simple. However, this setup is going to require at least 1ROR server and 1nginx/apache server (who says it can't be from the same machine?). Media will have to be loaded off non-ROR server.
So I talked about WP CMS themes, Wikis, ExpressionEngine, Radiant CMS. But there are way more out there, such as Drupal. I personally think it's much more difficult to theme Drupal or Joomla. (It's much like how it's impossible to theme phpBB3 because of its behemoth size). However, there are always usually a theme named Framework or "Reset" that make it easier.
What I'm trying to get at is all the software is basically the same. There is always a learning curve, but in the end, everything gets done the same. I bet AdamsBots could port their site to any CMS you throw at them. If your team has anyone who's been using particular CMS for a while, let that influence your decision because you have someone who already knows how a CMS works.
Thanks,
Keehun
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 10-11-2009, 09:36
REVving up for a new season
FRC #2848 (All-sparks)
team 2775 uses wordpress, and we love it. There are extensions for almost anything you want to do. Find a theme you like and modify it to fit your team.
www.libertyrobotics.com
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 10-11-2009, 09:43
NickE's Avatar
NickE NickE is offline
_
254 uses Joomla. We're still working to get a few bugs ironed out, but I would recommend it for its great selection of extensions.
Unread 10-11-2009, 09:56
Joining the 900 Meme Team
FRC #0079
FIRST in Michigan uses glFusion, it works pretty well. 397 used Wordpress but the site is currently down. TBA uses Tumblr for a good portion of their site. Personally I have used Wordpress and Tumblr. I haven't found any problems with any of them. Figure out exactly what you need it to do and make sure it can do it. Either that or find one of the open source ones and tweak it to do what you want.
Unread 10-11-2009, 13:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I used e107 for a site a couple years ago and it worked pretty well. You may want to check out www.opensourcecms.com
Unread 10-11-2009, 13:56
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Drupal, Joomla and Wordpress are the top three CMS clients I suggest.
I've used both wordpress and drupal extensively.
I use Drupal for all my websites now because they have the most flexibility & options. If you are just starting out on website development, I suggest wordpress as a first-time CMS package.
EDIT: Just found this article today - http://drupal.org/best-open-source-PHP-CMS-award-2009
PM me if you have any questions
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 10-11-2009, 18:43
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
As always, i'm the only one saying DotNetNuke. The only reason for this, is because for people that have no idea what the heck PHP is, VB.net is a lot more readable on this, and it uses more JavaScript for most things than actually generation.
But the other websites are very good. All of the above can be tested locally too (XAMPP) (except DotNetNuke which needs IIS and MSSQL express), so you can download all of them, mess around and decide which you like
2009 Championship Finalists & 3 Blue Banners
Unread 15-11-2009, 01:57
1986titans's Avatar
1986titans 1986titans is offline
1986: It's a team #, not a year.
AKA: Paul Shackelford
FRC #1986 (Team Titanium)
1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future1986titans has a brilliant future
We use Wordpress for our blog here.
The theme (Atahualpa) made it easy enough to customize everything, and I'd recommend it.
Unread 15-11-2009, 10:18
dqmot17's Avatar
Orange Hat
just a recommendation on your site there, is to fix those icons in the corner.. not looking so hot.
Unread 18-11-2009, 23:01
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
I've always been a fan of Joomla and Wordpress. I haven't wrapped my head around Drupal yet, but I hear it's really great, and it seems to be popular, so that's definitely another option.
I second the recommendation of browsing this site: http://www.opensourcecms.com/
It features nearly every CMS/platform worth using, and provides a front-end and back-end demo for every single one of them.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 19-11-2009, 12:48
rdlevy1215's Avatar
rdlevy1215 rdlevy1215 is offline
FRC #1676 (Pascack Pi-oneers)
rdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud of
1676 currently uses WordPress and it does an excellent job: www.team1676.com - but in the past we have used PHP-Fusion (both are free) and work extremely well. We changed over to WordPress because it was a little more customizable to our liking and generally looked a bit "nicer" ... to view our old "PHP-Fusion" site, go to: www.team1676.com/old-news.php
Good Luck!
Robert D. Levy
Team 1676, "Pascack Pi-oneers"
http://www.team1676.com/
admin@team1676.com
Unread 25-11-2009, 21:10
hyperdude's Avatar
hyperdude hyperdude is offline
Techie.
AKA: Mike W.
FRC #2503 (Warrior Robotics)
hyperdude has a spectacular aura abouthyperdude has a spectacular aura abouthyperdude has a spectacular aura about
For Team 2503, I code it by hand. I'm starting to think about just wiping it clean and putting in a CMS (save me the trouble of all the PHP work, plus designing it myself).
http://brainerd-robotics.org/
Unread 29-11-2009, 18:33
psrobichaud's Avatar
psrobichaud psrobichaud is offline
Computer Geek
AKA: Paul
FRC #2472 (Centurions)
psrobichaud is an unknown quantity at this point
Send a message via AIM to psrobichaud
Team 2472 uses the Joomla CMS with several extensions, including a Facebook page stream. For the design, we bought and modified a template made by RocketTheme. It was a little tricky to learn at first, but the result is much better than anything that I could have done (at least, in my skill set) with HTML and CSS. Once you learn its in's and out's, Joomla is easy to work with, and allows team members to post content without needing an html editor, ftp, or coding knowledge. The WSIWYG editor is very nice, and it allows modification of the html, if needed. I would definitely recommend Joomla as a CMS.
Check out our website at http://www.team2472.com
Paul R.
Team 2472 - Centurions
Media and Information Technology Leader
A little knowledge is a dangerous thing. So is a lot. - Albert Einstien
Solutions for No Shows MikeReilly General Forum 25 22-04-2009 10:17
Looking for linear bearing solutions Mona Technical Discussion 6 18-01-2007 19:40
New CMS website Sam Oldak Website Design/Showcase 3 03-09-2004 13:36
Looking for an easy website for your team? Jack Website Design/Showcase 2 30-12-2003 23:32
New Website For Team #957 Nate Edwards General Forum 2 31-10-2003 20:52
