Go to Post Without programmers there would only be a robotic beauty contest. - mallot1243 [more]
Unread 19-11-2009, 23:41
reversed_rocker's Avatar
reversed_rocker reversed_rocker is offline
Alumni
AKA: Ken Condon
FRC #0706 (Cyberhawks)
reversed_rocker is on a distinguished road
Re: pic: Cyber Blue Swerve Chassis - Rear View
when we built our crab drive, one problem we had was that the motor would over shoot the intended position, then try to swing back, and the process repeats.
we multiplied the difference between the wheels position and the intended position (the value read from the controller, translated to the same value range as the wheel position) by a constant less than 1 (ours ended up being around .57, but this is something you can define at the top of your code and mess around with) this way your wheels slow down as they approach the intended destination.
how did you solve the problem? maybe we could trade some code
Cyber Blue and Team 221 LLC "Wild Swerve" Chris Fultz General Forum 27 08-02-2010 14:47
pic: FRC-34 2009 Frame Concept (Rear View) Ed Sparks Extra Discussion 2 09-03-2009 11:00
pic: Cyber Blue Midieval Coast Chassis Chris Fultz Extra Discussion 7 10-12-2008 13:31
pic: Rear view of our 07 'bot Cody Carey Robot Showcase 7 16-02-2007 12:29
pic: 857 rear view programming CD47-Bot Robot Showcase 1 25-02-2003 22:24
