Go to Post Boy was that a sleepless night! - Suneet [more]
Unread 20-11-2009, 11:23
brreadd brreadd is offline
FRC #2638
brreadd is an unknown quantity at this point
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes
question in title.
Unread 20-11-2009, 12:40
Re: How do you run the pneumatics through the CRio w/o using the Jaguars and the Spik
By using the Solenoid Bumper in slot 8.
Connect the red & black wire from the solenoid directly to the 2-pin Solenoid Bumper. You have 8 available.
Single Solenoids will take up one set of Solenoid Bumper output pins, while Double Solenoids will require two sets of Solenoid Bumper output pins.
In programming use the Solenoid functions to control it.
Unread 20-11-2009, 15:06
JDM JDM is offline
programming lead; team executive;..
FRC #2199 (Robo-Lions)
JDM is on a distinguished road
Like Mark said, you will be able to run the solenoids through the breakout. However, there's nearly no way to get around the spike that you need to run the compressor.
(Sorry if the solenoid answer was all you needed, but your question wasn't very specific)
Unread 20-11-2009, 15:35
Remember that the compressor is 25 amps start current (10-12 amps run) while a solenoid is in the 20 ma range. Spike designed for 20 amps continuous, bumper is not.
Using Pneumatics with the CRIO? nighterfighter FRC Control System 9 18-10-2009 22:59
Connecting to cRio, getting the jaguars to go solid yellow.... then nothing. DSST\neal.ian FRC Control System 11 30-01-2009 18:15
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
Can you use the spikes with the globe motors? Caleb Fulton Electrical 1 15-02-2003 20:13
