Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Unread 24-11-2009, 23:58
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
LabVIEW "can't find" items when building a source distribution
I was investigating the possibility of Beta Test Team code to be backsaved to LV 8.5 so the rest of us could view it.
The method I was planning on was to create a source distribution, including vi.lib, and then somehow save for a previous version (en masse). (Because I don't have LV 8.6, I would try saving for 8.2. or 8.0)
However, I kept running into this problem:
LabVIEW says it can't find an item in ~\vi.lib\Robotics Library\NIFPGAInterface\, though when I find it manually, it's exactly where LabVIEW says it should be.
Is this a deterrent for people copying items from vi.lib? I'm certainly not interested in manually finding several hundred VIs just to test if the mass-backsave will work.
Maybe the best option would be to take that whole robotics library and make it part of the project?
-- Marshal Horn
How can you make "instances" of a subVI in LabVIEW when it is used repeatedly? RoboMaster NI LabVIEW 1 30-03-2009 21:37
warning when "Building" Code nick_champ_2 NI LabVIEW 2 25-01-2009 11:18
do we "NEED" the power distribution block seanl Electrical 33 03-12-2007 07:18
"VENDORs", reasonable delays in shipping due to out of stock items, and other errata Madison General Forum 12 08-12-2006 18:14
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
