Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 25-11-2009, 12:12
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
GP question
Back at the Portland Regional in 2009 I was working on a basic autonomous: go forward a ways, and then spin until the end of autonomous.
(I had some 'fire on trailers' code too, but the coach asked me not to enable it because it wasn't well-tested)
Anyways, I think there were problems with it not turning soon enough, and for some reason I decided to use a "delay and feed" on the user watchdog to see if that was the problem. What ended up happening was the wheels didn't stop after 15 seconds. Or when we "disabled" the robot. As far as we knew, they didn't stop until we physically shut the robot off. (I can make speculations from memory, but the why isn't so important in this case)
So I fixed that and was ready to test again, and then these two guys from another team came over and wanted to help. This is where GP comes in.
I wasn't really interested in their help, but I wasn't sure how to communicate it, so I went along with it.
The first thing they said was that a Case Structure was a loop, and that's where the program was getting caught up, so I needed to use a local variable to pass data out of it.
I had been working with LabVIEW for over 6 months at that point. I wasn't sure how they got that idea. I told them it wasn't, I made an example VI to show that it wasn't, and it wasn't until I spent 5 minutes with my head in my hands wondering how I could explain this to them in a way that they would get it, that they remembered what a case structure actually was (an "if...else" statement) and then left.
SO I tried to be gracious and professional, and I ended up wasting 15 minutes that I could have spent working. Perhaps I was slightly too gracious.
What should I have done?
-- Marshal Horn
Unread 25-11-2009, 12:29
Joining the 900 Meme Team
FRC #0079
Re: GP question
First, thank you for taking the time to explain to the two guys that they were wrong and thank you for not just blowing them off. I am sure they had every intent on helping if they could.
Second, whether you were too gracious or not depends on your priorities. For me learning and helping others learn is far more important than winning. For some people they would rather just win. There is nothing wrong with either view.
I am sorry I could not give you a definitive answer but like Alan Anderson said, GP is like a compass. It won't tell you where to go but it will help guide you if you know where you are going. If you know that your priority is helping people grow then GP will guide you one direction, if your direction is inspiration through demonstration then GP will guide you a different direction.
Hope this helped.
Unread 25-11-2009, 12:40
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
Re: GP question
I don't think that anyone would have been offended if you had just explained that you knew what was wrong and wasn't in need of any assistance while letting them know that you appreciated the offer.
Hope that helps.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 25-11-2009, 12:43
Re: GP question
Thanks guys, I appreciate the offer. I'm pretty sure I have this bug nailed down, but I'll be sure to come grab you if I don't.
Unread 25-11-2009, 13:36
Re: GP question
This.
If somebody offers help where it isn't needed, you can simply say, "Thanks, but we're good for now." If they persist in asking to help, you go to "The best way for you to help us is to let us do X. We'll ask you when we need help." (X ideally involves them not being there.) If for some reason they still stick around, have a mentor talk to their mentor about being too helpful. If it gets to that point, then I don't think anyone will have a problem with your telling them to go find another team to help, other than the overly helpful helpers.
Now, if they're giving wrong information, and they try to convince you it's right, the best thing to do is to convince them that their information is wrong--in a gracious manner, of course. This is what you did.
In short, it's possible that you were a little too gracious, but you're going to have to be the judge of that. Gracious Professionalism is a balance between being gracious and being professional. Sometimes you go a little too far one way and sometimes you go a little too far the other way. How far is too far? You make the call.
Unread 25-11-2009, 13:51
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: GP question
That's pretty much how I would put it.
I'd probably go by afterwards, towards the end of the competition and thank them again, too.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 25-11-2009, 14:27
Re: GP question
-Nick
Good point. Perhaps your response to other teams that offer help after could be "Thanks, but Team 12345 already [helped out / offered to give me a hand]!"
question merybar General Forum 3 02-04-2008 11:09
Question fredliu168 FIRST Tech Challenge 2 13-09-2006 17:33
Question Joker12 Programming 0 21-02-2006 13:23
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Question Finch Rules/Strategy 5 11-02-2002 21:47
