Go to Post Okay guys I am enabling the robot. Honestly I have know idea what it is going to do. SO MOVE!! - JulieB [more]
Unread 24-11-2009, 12:12
Team 288's Avatar
Team 288 Team 288 is offline
Team 288 - Spare Parts
FTC #0288 (Spare Parts)
Team 288 is a jewel in the roughTeam 288 is a jewel in the roughTeam 288 is a jewel in the roughTeam 288 is a jewel in the rough
Question [FTC]: NXT bluetooth connectivity issue
I am a programmer for three teams here at Gateway High school, and I am having issues with my bluetooth connectivity. I am programming with LabVIEW 2009 and all NXTs are updated to firmware v1.28.
When I plugged in the bluetooth dongle for the first time, it connects to a NXT, downloads and allows the FTC Controller Station to connect to it fine. But it only seems to allow the first NXT to ever connect to the dongle to successfully download code. I tried going into the properties of the bluetooth Support Service and changing the properties of it to Logon As a Local System account, but with no avail.
Any ideas?
Charlie Blair
Electronics Instructor at Gateway Institute of Technology High School
Head Coach for FTC teams at Gateway Institute of Technology High School since 2005
Planning Committee Member, St. Louis Regional FTC
Mentor to Team 931 Perpetual Chaos since 2004
FRC Volunteer
Unread 24-11-2009, 15:25
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: [FTC]: NXT bluetooth connectivity issue
Make sure Bluetooth is turned on for all the bricks. When you hit the search button (looks like a magnifying glass) it should find an list all NXT bricks in range. This being said the FTC Controller Station only allows for one connection to a brick at a time.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 25-11-2009, 08:15
JohnFogarty's Avatar
AKA: @doctorfogarty
Any ideas?
Have you gone through LabVEIW with NXT Link setup
John Fogarty
Unread 26-11-2009, 12:38
saaby's Avatar
saaby saaby is offline
AKA: Taylor Cannon
FTC #0127 (Fighting Pickles)
saaby can only hope to improve
Last year my team was using two bricks (in case one failed in competition). We had similar issues. First try having only the brick you wish to connect to on. So if you want to connect to brick C, A and B should be off. Even if you have already connected to a different brick this should work. If not then try going into the blue tooth settings in the control panel and deleting the NXT device you just connected to. Then turn off all of your bricks. Turn on only the one you wish to connect to and search for it with blue tooth. This was worked for our team every time. The key (I think) was deleting the device from the saved blue tooth device list.
LabView Connectivity Issue - HELP NEEDED Neurovirus NI LabVIEW 1 10-02-2009 22:50
cant get NXT to connect to controller station via bluetooth cougarbotics FIRST Tech Challenge 5 04-12-2008 00:19
[FTC]: FTC Controller Station Connectivity (Bluetooth and USB) Issue jbbjjbt FIRST Tech Challenge 6 05-11-2008 11:49
[FTC]: Bluetooth/NXT issues jbbjjbt FIRST Tech Challenge 5 23-10-2008 16:56
Workshop Connectivity Issue Compnerd IT / Communications 7 30-01-2008 19:08
