Go to Post Lets have fun this year - Wayne Doenges [more]
Unread 27-11-2009, 13:46
aybose aybose is offline
FTC #2485
aybose is an unknown quantity at this point
[FTC]: Our motors are too slow :(
We are programming in Labview, and have just a simple block to maximize our power to 127 on our motors. We have a 1:26 gear ration, and the motors are still waay to slow. Is there some other block that should be in the program to get to the max speed?
Unread 27-11-2009, 16:58
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Our motors are too slow :(
a 1:26 should give roughly 3100 RPM of the shaft (give or take a few RPM). Try hard-wiring it to the battery and make sure your batteries are fully charged. You also might not have the cable in the motor controller all the way. Check all the wires make sure they all have a secure connection.
What is the set up of the compound gearing system?
because i think you might have a 1:27 instead of a 1:26 just to be clear
Unread 30-11-2009, 10:53
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Are you using the Joystick VI? This VI has an input called Throttle that has a default value of 50. This means this VI will at most output a power of 50% to the motors. Changing this input to 100 allows for the full range of power output from this VI into a Move Motor VI.
Cheers,
Mark
LabVIEW R&D
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
[FTC]: Slow Down Max Speed!! JohnFogarty FIRST Tech Challenge 10 16-11-2009 13:24
Analog to Digital Conversion too Slow Dave McLaughlin Programming 2 09-02-2008 23:21
Camera servos too slow, help please Lablabla Programming 9 19-01-2007 11:59
Kitbot/cims/transmissions running too slow? Swampdude Technical Discussion 28 23-01-2005 11:17
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
