Go to Post Half your robot could be broken, some drive chains snapped, a drive motor burned out, etc... and your WCD will still be trucking. - AdamHeard [more]
Unread 25-11-2009, 16:42
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
logitech dual-action gamepad
I went out and a Logitech dual-action gamepad to play with, because it's USB plug-and-play (PnP), so it follows a common standard.
So...
How do I use it with LabVIEW?
It doesn't show up on the Measurement and Automation Explorer.
I can't seem to find the USB PnP standard, either, so I'm in the dark as to what the correct baud settings and such are.
Any ideas?
-- Marshal Horn
Unread 25-11-2009, 16:46
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Question Re: logitech dual-action gamepad
What do you have the controller plugged into, a target like the DS or the computer?
Unread 25-11-2009, 20:25
In the connectivity palette is a submenu of VIs for querying HID devices (Human Interface Devices). It should list the mouse, keyboard, and your joystick(s). There are also VIs for opening a connection and reading the button and axis and POV state.
Greg McKaskle
Unread 26-11-2009, 00:37
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
If you want to use it with the Control system for a FIRST robot, this is quite easy to do. We have a Logitech gamepad for our team to and it works great. Just acquire data from it the same way you would a normal FRC joystick. The buttons and axis will be switched around though, so I suggest you make a test program to see which buttons react to which default button number.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 28-11-2009, 16:58
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
On another note, the Logitech gamepads I've used in FTC (I know, different realm, but might still be relevant) have always reported negative values from what you'd expect. This might just be signing issues with the NXT/FTC Toolkit, I don't know, but do watch out for that.
Also, as RoboMaster said, the buttons and axes may not necessarily line up how you expect them to. I would suggest making a "wrapper" VI to simplify usage, basically a custom-made VI that contains the regular VI, but outputs the pins to the correct configuration for your gamepad. Then name it something like Gamepad.vi so you can use it more intuitively.
Unread 28-11-2009, 19:50
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Thank you, it works great.
Daltore:
It appears to work mostly as expected; the axis are polarized intuitively, the buttons correspond correctly. However, the right joystick is the "z axis" and "z rotate", while the left joystick is "y axis" and "x axis".
-- Marshal Horn
Unread 19-01-2010, 20:47
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Here is a chart for the Logitech Dual Action controller. Tested in lab view code which i will be more than willing to give out the .vi if anyone wants it(id post it if i knew how).
http://tinyurl.com/y9sx84c
New class for Logitech Dual Action Gamepad Mike Soukup C/C++ 8 11-02-2009 20:08
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
Gamepad Controller Mike375 Technical Discussion 13 05-03-2002 21:20
