Go to Post Your attribute of personal sacrifice is very noble, but FIRST needs YOU to be successful first. - DanKein [more]
Unread 29-11-2009, 00:49
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Sensors!
Hey all, I need to make a list of all the sensors that can be hooked up to the crio. Any sensor you've seen hooked up, please post it!
My list so far:
gyroscope
accelerometer
touch
potentiometer
encoder
camera
ultrasonic
(i feel like I'm missing something obvious...)
any more will be appreciated greatly. Thanks in advance!
Unread 29-11-2009, 00:52
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: Sensors!
My list so far:
gyroscope
accelerometer
touch
potentiometer
encoder
camera
ultrasonic
Our team hooked up a photogate (I think that's what you call it) in 2006. Basically it was an IR light and a sensor, so when the line of sight was broken, it would send a signal. I know cRIOs weren't around back then, but it just used a digital input, same as on the cRIOs.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 29-11-2009, 11:44
Re: Sensors!
You forgot about the wonders of the hall effect!
Current Sensors (Hall Effect)
Gear Tooth Sensor (Hall Effect)
Magnetic Rotary Encoders
Magnetic Linear Encoders
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Sensors!
My team used that kind of photogate on the cRIO this year, I can ask the guy who worked on it for specifics if you like.
Go REX!!!
Unread 29-11-2009, 11:59
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Sensors!
Don't forget about:
Temperature sensor (thermocouple), I bet there's a team out there at some point who put this on a robot.
Light Sensor.. True a camera could do this as well, but a simple light sensor can be straightforward to program as long as you calibrate at the competition venue.
And then there was the IR beacon in 2004 (basically a light sensor).
Unread 29-11-2009, 12:14
The Blue Alliance
Re: Sensors!
Oh and I think I heard about some teams using current sensors this year for their traction control?
Not sure though.
Eugene Fang
Unread 29-11-2009, 13:11
Gdeaver Gdeaver is offline
FRC #1640
Re: Sensors!
Don't forget the Panasonic IR distance sensors. Come in many different ranges in both digital and analog.
Unread 29-11-2009, 15:33
Re: Sensors!
We slapped a set of those on our practice robot, and used them to tell us when to give the robot a break to prevent overheating. Really useful, and I think all our future robots are going to be sporting one per motor.
Unread 29-11-2009, 16:06
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Sensors!
In fact, ANY sensor can be connected to the cRio; this then becomes a listing of 'all the different sensors that exist'.
This has some good info
Unread 29-11-2009, 16:28
FRC #1700
Re: Sensors!
Thanks a ton; I knew CD would have a lot of knowledge on this.
For lack of better words, that's awesome.
That's kinda what I wanted it to be, but mostly ones relevant to robots. Good link.
Unread 29-11-2009, 16:39
The Blue Alliance
Re: Sensors!
Looking at that link, I thought of one more that can be relevant to robots - a compass.
Pros: does not drift like a gyro does
Cons: can be affected by motors/metal/etc.
Eugene Fang
Unread 29-11-2009, 17:53
FRC #1700
Re: Sensors!
That's an interesting idea. This is off topic, but how much drift would the gyro accumulate over the 2 minutes? I assume it will be greater the more time you hit another robot/wall. What were other teams experiencing?
Unread 29-11-2009, 19:11
The Blue Alliance
Re: Sensors!
I'm not sure, since our team has never actually used gyros. I've just heard of other teams using them. However, I seem to recall teams using accelerometers to counteract for drift (I don't know how). A crude way to fix drift is to have a trimming potentiometer on your DriverStation i guess.
Sorry I don't have any hard facts. Maybe someone else has had some experience with gyros personally?
Eugene Fang
Unread 30-11-2009, 00:05
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: Sensors!
The short answer is there's no way to say for sure.
The long answer is there's a way, but it's really complicated. Basically, the amount of drift accumulated is very dependent on the code running the gyro. Gyros have different responses based on temperature, so some gyros contain internal thermometers that are also output to the microcontroller. Another factor is noise. If you have a gyro that communicates by serial (good luck finding one, I haven't seen any), it'll be more accurate than if you have a wire running around carrying an analog voltage that's varying. With the analog signal, you have to do averaging to get any kind of usable data, and when you average, you lose resolution. Since the cRIO has such a high data rate, you could probably get away with it a little more easily. Also, MEMS devices in general work by using capacitance between a central mass and an outer edge. If you have any static charge on your robot, it may or may not affect the gyro. Also, calibration of a gyro will not necessarily work if you move it to a different location on the robot, because overall capacitance will change, and may or may not affect the capacitive difference.
Unread 30-11-2009, 12:26
Jared Russell's Avatar
Taking a year (mostly) off
Re: Sensors!
I have done quite a bit of work with gyros and drift is one of the more difficult things to characterize. What we call "drift" is the effect of integrating the output of a noisy signal. In the case of a MEMS gyroscope, this noise is caused by small thermal variations and vibrations that are impossible to completely correct for. Imagine a variable with noise of +/- 1 unit at any given time. What happens if you integrate this variable? You get what is called a "random walk", or drift.
Because electromechanical noise is usually modeled as a random variable (frequently as white noise with a mean and a variance, but no single exact value), you can never say for certain what your worst case drift will be. But, you can calculate things like your "average" drift rate over time, or your drift over various confidence intervals.
Drift rate is affected by several factors, including:
* The gyroscope's noise properties
* Sampling rate
* Temperature
* Filtering
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
I R Sensors thoughtful Programming 2 06-02-2004 11:45
IR sensors alexrobotics Technical Discussion 23 27-01-2004 00:59
sensors edomus General Forum 5 19-11-2003 16:46
