Go to Post It is crucial to keep experience and keeping collected under pressure as high points that can't be measured in a test. - jnelly [more]
Unread 01-11-2001, 15:01
Frank Toussaint Frank Toussaint is offline
Frank Toussaint will become famous soon enough
additional materials: mylar?
Does the plastic on the list of additional materials extend to mylar?
Unread 01-11-2001, 23:31
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
The plastic listed was suppose to be the basic sheets and strips of plastic. We tried to not over restrict the list, but in some cases we may have been too vague. Plastic is a pretty big catagory. We are pleased to see that you are asking, better to be safe. Although mylar is a plastic, the answer really depends on how you plan on using it. Mylar material used as signage or decoration is okay. So can you tell us what your usage is without giving too much away?
Unread 02-11-2001, 14:38
We were considering a container to hold bottles. Think of a cube with a frame for the edges and mylar streched over the faces. If we can't use mylar then thin (< 1/32") sheets of lexan would probably fit the rules better.
Unread 02-11-2001, 16:06
volunteer helper
FRC #6099 (Knights)
Frank.
I agree with the 1/32" thick lexan - I'm sure that fits the rules and the mylar is really a stretch. Thanks for question though.
how can you get more materials? Ydnar 3D Animation and Competition 5 01-04-2002 22:04
Kit Materials Usage & Limitations Rockstar75 Rules/Strategy 1 10-01-2002 17:19
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Are additional pulleys "cable fasteners"? kmcclary Off-Season Events 6 26-10-2001 01:56
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
