Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 27-11-2009, 00:01
ezygmont708's Avatar
ezygmont708 ezygmont708 is offline
FAIL = First Attempt In Learning
AKA: Zygmont
FRC #0708 (Hatters Robotics)
ezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant future
NI LabView on Windows 7
Lenovo z61e
Windows 7 Enterprise - 32 bit
Intel Core Solo Processor T1300 @ 1.67Ghz
3.0 GB PC2-5300 RAM
The initial installation dialog from the root of the 2009 FRC Dialog will not work on Windows 7.
If you "Explore" the disc and navigate to the LabView Folder you CAN install the 2009 FRC LabView software as individual items. I am also currently working on installing and testing LabView on a Lenovo S12 Netbook with the following specs:
Lenovo S12
Intel Atom n270 Processor
2.0 GB PC2-5300 RAM
The netbook is definately a cheaper option, and with the 12" screen we simply purchased a 19" LCD monitor to accompany each.
This is not a recommendation as to whether or not to use Windows 7 as your Operating System.
Side Note...
I have noticed increased performace in LabView running on Windows 7
E. Zygmont
Team Lead - Team 708 Hatters Robotics
Hatboro- Horsham Senior High School - Horsham, PA
Unread 28-11-2009, 23:44
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Re: NI LabView on Windows 7
I hope new LabVIEW is going to work(and INSTALL) on Windows 7 64-bit system without any problem
NI declared that LabVIEW will NOT support Windows 7 officially for FRC version since they have not completed their compatibility test.
Unread 29-11-2009, 00:44
AKA: Zygmont
I don't yet have any experience with Windows 7 64-bit. I do know that there have been some compatibility issues with 64-bit and other applications.
E. Zygmont
Unread 29-11-2009, 08:39
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
As a side note, but related, Inventor and Solidworks (both student edition, both '09) installed for me without a problem in Windows 7.
GitHub
Unread 30-11-2009, 08:02
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Unofficially, I do have SolidWorks 2009 - 32 bit running on my laptop with Windows 7 installed.
Please note that the NI software application NI SoftMotion that allows you to communicate between LabView and SolidWorks Motion has not been tested on Windows 7 and requires SolidWorks 2009 SP4 or greater. We will work on this for next year. http://zone.ni.com/devzone/cda/tut/p/id/10099
Marie
Unread 30-11-2009, 10:27
JohnFogarty's Avatar
AKA: @doctorfogarty
Marie
LabVIEW 2009 for Tech installed on Windows 7 Ultimate and works fine.
John Fogarty
Unread 30-11-2009, 23:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If the labview version that the beta testers have received is any indication, you will NOT be receiving labview 2009 at the start of the season: we are all using 8.6.<insert latest beta update here> - but who knows what FIRST has up their sleeves.
That said, we have several beta testers running labview on windows 7. The installer didn't work (they had to install each component individually) but once they had it up and running, it wasn't an issue.
That said, I've been on the more conservative side when it comes to computer programs. Bleeding edge usually means problems, and we already have enough of those with our robot without worrying about finding new problems on unsupported software interactions
Unread 03-12-2009, 10:33
AKA: @doctorfogarty
Ok i got a question i have 2009 LabVIEW where the nut would i find the FRC Toolkits and addons?
John Fogarty
Unread 06-12-2009, 23:44
AKA: Zygmont
To my knowledge you cannot get an FRC Toolkit or addons for LabView 2009
E. Zygmont
Unread 08-12-2009, 10:38
AKA: @doctorfogarty
If onlt the world made sense, cause i know FTC all you have to do is get a add on why couldn't they do the same for FRC.
John Fogarty
Unread 15-12-2009, 16:19
Eli's Avatar
Eli Eli is offline
Team 3089
FRC #3089 (Team 3089)
Eli is an unknown quantity at this point
Send a message via MSN to Eli
Unread 15-12-2009, 20:03
The testing that was done with Win7 succeeded, but since LV 8.6 shipped long before Win7, it wasn't complete. Some of the beta members used Win7 and there were no issues that I remember. What NI is saying is the same thing they say anytime a product has incomplete testing.
Greg McKaskle
Unread 11-12-2010, 11:55
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
Hi, I was searching for help on how to install the 2010 Labview (last year's)on windows 7, we got the "starter edition" on our netbook, a
Gateway LT2030u with the following:
Intel Atom processor N270
10.1 LED LCD
HDD 250 GB HDD
1 GB Ram
Windows 7 Starter.
I just need clarification on what you mean by install each items individually...Thank you.
Windows 7 McGurky Rumor Mill 142 15-07-2009 20:11
Windows Vista ThomasP Chit-Chat 15 01-02-2007 07:16
MySQL on Windows Venkatesh IT / Communications 6 27-06-2004 19:12
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
