Go to Post Putting 2 and 2 together, and then mixing them back up for someone else to try and get 4 in a different way is just plain fun. - Elgin Clock [more]
Unread 01-12-2009, 07:36
MikeReilly's Avatar
MikeReilly MikeReilly is offline
FRC #4509 (Mechanical Bulls)
MikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud ofMikeReilly has much to be proud of
Accounting/Inventory
Anyone out there have a good accounting/inventory system for your build? We've been using the Federal Bailout method of spend a lot, get in trouble, beg for loan forgiveness. It's worked so far, but....
Seriously, any good Access or Excel stuff that's really good? Thanks for any help.
Mentor for Rookie Team 4509, Formerly with 1771
Unread 01-12-2009, 08:23
ttldomination's Avatar
Sunny
Re: Accounting/Inventory
Hello,
Our Motorola mentor takes care of the primary order placing. But I think that Excel would best serve your needs. Just make a chart with the functions in place, and put in your spendings.
As far as inventory is concerned, we don't have a hard copy of everything, but everything is pretty organized so we're on top of what we have/what we need.
1648: 2013-2014
5283: 2015
Unread 01-12-2009, 10:33
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The past couple years, I've done most of the purchasing of robot parts. I think Forbes is a Scottish name? Maybe that's why I'm so thrifty?
We only spend money if we really have to, because we know how hard it was to get.
I hear you can make a successfull robot with the relatively cheap plywood they sell at the hardware store.
As for keeping track of it....doesn't matter what you use, the important thing is to have a plan before you start buying stuff.
Unread 06-12-2009, 23:47
ezygmont708's Avatar
ezygmont708 ezygmont708 is offline
FAIL = First Attempt In Learning
AKA: Zygmont
FRC #0708 (Hatters Robotics)
ezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant future
We use Google docs to co-ordinate our budget / purchasing. Just create a spreadsheet with each item as you purchase it and the quantity. Be sure to create columns for: On the Robot | In Supply | Broken Defective
This also helps with creating the Robot Breakdown for inspection.
E. Zygmont
Team Lead - Team 708 Hatters Robotics
Hatboro- Horsham Senior High School - Horsham, PA
Unread 07-12-2009, 00:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I just use an Excel spreadsheet where I list everything, where it's coming from, total cost, shipping cost, what/which team it was used for (as we purchase things for 254/1868/our lab), and when it was ordered.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-12-2009, 00:57
We've used Peachtree accounting...mainly because we have a CPA on the team =P
Unread 15-12-2009, 23:25
kevinhorn kevinhorn is offline
FRC #3213 (Thunder Tech)
kevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nicekevinhorn is just really nice
We use a google doc for our BoM and some of our purchasing.
Here is the Data for the 2009 KoP
You are welcome to copy and adapt it to your needs. The part numbers in blue are hyperlinks to the sellers webpage. This makes finding parts a lot quicker. Warning; some links have changed. I will make a new set of sheets for the 2010 KoP and fix any broken links after kickoff.
The 2010 BoM spreadsheet will be posted here
Google spreadsheets works well with people who may need to collaborate from different locations. This allows mentors to discuss via skype and both parties may enter data or view the spreadsheet at the same time. I know that some will prefer excel. Whatever works best for you is the best.
Unread 21-12-2009, 12:52
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I think the key is to limit the people who can purchase items for the team. On our team, we have a few mentors who make almost all the purchases for the team (although occasionally students will want to do it, and they can buy some specific things from local sources). It's done this way for a few reasons. First, we can usually get stuff at discounted prices by ordering through our suppliers at work. Second, it ensures that we don't over-spend. All of the mentors on the team are pretty thrifty and know how to spend on a budget, while students can often have trouble with that.
At the beginning of the season, we prepare a rough budget - we know going in, for example, how much the bus is going to cost, how much the hotel is going to cost, etc. We can also look at our inventory and past experience and judge how many spikes, victors, jaguars, or motors we may need to buy. We may be right, we may be a little off, or we may be way off. But it's a rough budget that allows us to say (numbers are made up) "we'll spend around $400 on electrical components, $700 on mechanical components". That can all be done before the kickoff.
After the kickoff, we spend a few days developing our design, and a week or so prototyping with whatever material is on hand. During that time, you can really nail down the numbers - you can figure out exactly what motors you need to buy, how many motor controllers, approximately how much stock aluminum, etc. Normally, you're going to have a number at this point that's lower than your actual spend for the build season - to be safe, budget yourself and extra 25% for robot parts, and use whatever is left over for a team dinner at the end of the season.
One of the keys here, though - budgeting is just as important as everything else you do, and it goes hand in hand with your design/prototyping phase. You may come up with the best design in the world, but if you can't afford to build it, you should get started on the second best design that you can afford.
On an interesting note, this is how companies do it, too. Typically, you have a small budget for research/prototyping, and when something shows promise, you get a budget approved to develop it. Where I work, we call that going to contract. Once you go to contract, you have a due date, a fixed budget, etc... You can't decide (at least, not very easily) halfway through the project that you're going to need more money.
Unread 21-12-2009, 13:03
AdamHeard's Avatar
Lead Mentor
I agree here.
On my team, I made a pretty decent excel we use for handling ordering. Anyone on the team can talk with me about acquiring items (I encourage students to do the bargain hunting; which some really, really surprise me with) and have items added. This list is then reviewed by myself and the lead mentor, and we order from there.
Unless we get substantially more mentors, I don't think we'll change it. It's really nice for both of us to know pretty much everything the team has purchased.
Inventory? Clifford FRC Control System 3 17-12-2008 23:04
Inventory Management NickJames General Forum 4 28-12-2007 18:24
2007 Pneumatics inventory Commander07 Pneumatics 3 28-01-2007 19:05
Autodesk Inventory Tutorial team_mom Inventor 13 24-01-2006 12:31
Yearbook Page Inventory nwagers General Forum 3 18-02-2002 20:31
