Go to Post Making GP a rule would be the equivalent of making a law that says you have to help get kittens out of trees. - Molten [more]
Unread 30-11-2009, 18:10
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
[FTC]: Autonomous Code Ender
Hi there, I am a relatively new FTC-er and I had a question about the autonomous coding in ROBOTC. Is there a way to make a while loop abort after a set amount of time, say 20 seconds, even if it has not completed its usual task? Because we are having our robot find the center goal during autonomous and fire balls into it, but if the sensors do not find the beacon or the robot cannot center on it we need our robot to automatically abort the while loop and start other tasks.
Any help would be greatly appreciated.
Unread 30-11-2009, 21:06
Monty Python Monty Python is offline
Monty Python has a spectacular aura aboutMonty Python has a spectacular aura aboutMonty Python has a spectacular aura about
Re: [FTC]: Autonomous Code Ender
You can set a while loop as less than one of the timer's in robotc. You'll have to check the help files for the exact syntax as I don't remember it offhand, but if I remember correctly, I think it looks something like...
while(T1<20000)
//put code here
I think that T1 is a millisecond timer, but just search the help files in RobotC for timer and you should be good to go.
Oh and you probably want to set T1 equal to 0 at the beginning of autonomous, but I'm not 100% sure (again, the help file should tell you everything you need to know).
Unread 01-12-2009, 15:41
clwilligham clwilligham is offline
FTC #2845 (Team Duct Tape)
clwilligham is an unknown quantity at this point
you can do that if you make sure you clear the timer first, or if you want to have it go through a loop a specific number of times you can use a for loop
for(int i=0; i < 10; i++)
//code here
if you want to use timers, i'm pretty sure the syntax is timer[T1] to read or write the timer.
to reset a timer you would just to timer[T1] = 0;
Unread 01-12-2009, 20:29
AKA: Ryan Zoeller
Thank you both for the help
Unread 03-12-2009, 07:32
lmnotran lmnotran is offline
AKA: Mason Tran
FRC #2169 (KING TeC)
lmnotran is an unknown quantity at this point
Good thinking
__
Mason Tran
[FTC]: 3033 Autonomous! Mushrooshi FIRST Tech Challenge 6 21-04-2009 22:19
[FTC]: 121 Autonomous gregsanCHEVY121 FIRST Tech Challenge 20 10-04-2009 23:10
[FTC]: Autonomous saaby FIRST Tech Challenge 8 19-02-2009 12:45
Video: FTC 3 Cloverfield Autonomous Synergy1848 Robot Showcase 0 26-02-2008 14:34
Autonomous code PBoss Programming 7 14-01-2003 15:29
