Go to Post FRC did a lot for me in high school. I couldn't pass up the opportunity to help it do the same for others. - Oblarg [more]
Unread 02-12-2009, 08:23
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Could use some help...
Ok, I know there isn't a direct Thread location where I can post this problem on here but I figured I'll post what I need to ask in this General Forum...
Ok, I have a '00 Blazer. I recently purchased a new factory '09 Radio thats found in most '09 GM Vehicles. The '09 vehicle it "came from" was a Cobalt.
So here's what I need:
1) Wiring Diagram for the '09 Radio from a Chevy Cobalt. In specific the Ignition Circuit on the radio side. I know where it is on my '00 Blazer but can't find it on the radio.
2) An Antenna Adapter going from the '09 Factory Radio to the '00 Blazer currently installed Antenna. While I don't think one "exsists" I'm praying one does. If I'm not mistaken the one on the '09 Radio appears to be a Coax type deal. I'm assuming both ends of what I'm looking for needs to be Female.
So any help you can provide will be greatly appreciated... (don't ask why I'm trying to use a new Factory Radio in an old SUV =P ).
Thank You CD =D and good luck to all in '10
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 02-12-2009, 17:29
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Could use some help...
This isn't really the place for this question. Your best bet is to try www.cobaltss.net
The guys on there are really helpfull, and I bet they could provide the information you need. And since Im a member, Ill take a look and see if I can find the diagrams for you.
EDIT:
Heres the pinout for the radio http://www.cobaltss.net/forums/showthread.php?t=2823
If your looking for a "remote" wire for the radio, you can use any wire that has power only when the key is in, just use a circut tester to find one.
As for the antenna, Im 98% sure there isn't an adapter for your application
Hope this helps!
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 02-12-2009, 17:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
from the link: "the radio DOES communicate on the Lowspeed GM-LAN line, it recieves VIN information for TheftLok, illumination dimming inputs, and signal for speed compensated volume."
interesting...have fun!
Unread 02-12-2009, 17:50
AKA: Scott
Exactly, forgot to include that little bit...the electronics in new GM vehicles are run via the BCM (body control module)...Which I doubt your '00 Blazer has, and even if it did, I doubt it would communicate properly with the cobalt radio. Also, if you do get it to work, your going to need the code to unlock the radio...Good luck with this little project.
Unread 02-12-2009, 21:30
Originally Posted by mtaman02 View Post
...In specific the Ignition Circuit on the radio side. I know where it is on my '00 Blazer but can't find it on the radio and I know there has to be one...
There most likely isn't one. The recent GM radio I'm working with right now only has a single power pin, connected to the battery (through a fuse, of course). It finds out whether the ignition is on by listening to messages on a serial data bus.
Unread 02-12-2009, 21:47
MrForbes's Avatar
AKA: Jim
I miss the days of real switches....my wife's new truck takes a moment to think after turning the key, before it will engage the starter.
Unread 02-12-2009, 22:02
Gdeaver Gdeaver is offline
FRC #1640
This thread has allot to do with FRC robots because if we ever get the can option many parts of our robots will be like this.
Unread 03-12-2009, 08:41
mtaman02's Avatar
Yea, I know this isn't the place for Auto Questions =)... But I figured FIRST has got alot of young drivers just like me who like to take things apart in their own car to try and alter the way it originally came =P.
Ok, so the wiring diagram that you pointed me to and the one I have are the same so I guess unless I decide to keep going looks like I'll hang up the towel on this lol.
As for the Antenna, I would probably have to go out and buy the whole antenna to radio harness and antenna itself.
As for programming and TheftLok. I work part time in a mechanic shop so to get the theftlok code isn't a problem so I would just need to drop by the dealer and get them to program the radio.
I do Thank all of you guys for all of your help thus far. Knowing and accepting what my next step is will have alot to do with keep going or just get the Pioneer P5100UB =P. Since I know the aftermarket radios go in 1-2-3 =P. Just got to find a dash kit =P.
Volunteer Resume:
Unread 03-12-2009, 10:23
MrForbes's Avatar
AKA: Jim
Or build your own. It's not much different from building robots.
I think I swapped a mid 60s Oldsmobile radio into my 59 chevy truck when I was 16....wiring was so simple back then, the yellow wire went to switched power, that was about it.
Unread 04-12-2009, 08:53
mtaman02's Avatar
We'll see what happens. Right now I'm sick as a dog and can't do anything... so either way my hands are tied.
Volunteer Resume:
I could use some help. . . Kanoajoe Chit-Chat 5 24-02-2008 21:25
could use some programming help. mtaylor Programming 2 23-01-2005 10:54
could use some programming help. mtaylor Technical Discussion 2 23-01-2005 10:54
iF could use some help Nick Mac FIRST-related Organizations 0 12-05-2003 21:26
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
