dashboard in visual studio?
Can I make a dashboard program in visual studio? If so, how do I do it?
Re: dashboard in visual studio?
yes, there is a standard network UDP packet send every 50 ms.
you can receive UDP data from port 1165, and process the data. this thread has the details for the auto-generated data, you can send and parse your own data (984 bytes) too: http://www.chiefdelphi.com/forums/sh...ad.php?t=72874 (last post, first image) |
In addition, the new driver station software allows you to choose the dash board executable to run when it launches, so it should work with any compiled (.exe) file you choose to use. However, let me point out that you can do MANY things in labview as easily as in visual studio. I had original intended to write a automous mapping program in visual studio (because I'm familiar with it), then I took a look at labview and realized it would actually be easier!
| Visual Studio C18/MPLINK build rules >>>HERE<<< | itsnotabigtruck | Programming | 4 | 03-03-2008 07:48 |
| Visual Studio 2005 SP1 | EHaskins | Programming | 0 | 21-12-2006 11:36 |
| Custom Dashboard - Visual Basic | Mike Lat | Programming | 3 | 23-01-2005 14:26 |
| Any pratical use for Microsoft Visual Studio .NET Pro | Kyle Fenton | General Forum | 11 | 28-01-2003 16:59 |
| Visual Basic 6 Dashboard | LBK Rules | Programming | 1 | 22-01-2003 13:06 |
