Go to Post I always tell newbies that if you build a great team the great robots will follow. - Wayne C. [more]
Unread 30-11-2009, 13:12
blackiceskier's Avatar
blackiceskier blackiceskier is offline
ziggy!!!
AKA: josh T
FTC #3041 (URSA MAJOR)
blackiceskier will become famous soon enoughblackiceskier will become famous soon enough
Send a message via AIM to blackiceskier
helix
ok CD we could really use your help. we are a FTC team and for this years game we are tying to make a helix so if you could add your input that would be great
would it be better to use a stiff bristle or a soft bristle. mind you we are picking up whiffle balls
would the pick up bar be better direct motored or chain/gear driven??
remember we are using the legal FTC KoP so keep your FRC minds a little bit retained
thank you
Unread 30-11-2009, 13:18
Joining the 900 Meme Team
FRC #0079
Re: helix
Prototype both, see which works for you. I'm not trying to be sneaky and not tell you the answer, honestly the best solution is to try it and see.
Good luck.
Unread 30-11-2009, 13:21
ziggy!!!
AKA: josh T
Re: helix
we have tried out a stiff bristle and this seems to work but our team is having some discrepancies so i decided to come and ask the CD world and see what every one else preferred because this past FRC season we watched some matched and there were some of each so this is really throwing off all of our plans because as a team we cannot decide
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: helix
definitely need to experiment. We used the grippy stuff (shelf liner) for our FRC helix robot for Lunacy. We made flaps of it that would stick out of the center tube. Worked great.
Unread 30-11-2009, 13:23
Jared Russell's Avatar
Taking a year (mostly) off
Re: helix
There is no single answer to this question. Finding the right balance of bristle stiffness, density, and length is almost impossible to do without playing with different combinations until you find the one that works best.
Unread 30-11-2009, 13:25
ziggy!!!
AKA: josh T
Re: helix
well thanks for that picture but the only thing we have along the line of shelf liner is non-slip padding. as far a bristles we have tried zipties and they seemed to work ok but we are looking for other ideas as well. what sugestions are there for the drive of the center rod????? either chain driven of direct motored?
Unread 30-11-2009, 13:32
Re: helix
Not being involved in FTC I'm not sure what parts are allowed to be used this year, but I have seen effective spirals made out of strip brushes (from McMaster), paint brushes, hair brushes, sheets of lexan, tubing (like the picture posted in this thread), cardboard, zip ties, hose clamps, and many other materials.
Unread 30-11-2009, 15:07
ttldomination's Avatar
Sunny
Re: helix
For the drive of the center rod, you want to keep it compact so whatever works for you.
As for what the material would be, if you attach a tube of PVC to an axle connected to your drive on the top, and then with an idler axle at the bottom, it should run pretty smooth.
I don't think you need to use more than one motor for the helix drive, probably geared for torque.
1648: 2013-2014
5283: 2015
Unread 30-11-2009, 15:57
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: helix
We have a team here who did a ziptie tree with a helix design it works great
John Fogarty
Unread 30-11-2009, 16:43
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: helix
zip tie trees. PVC trunk. I leave the rest of the fun to you. but make sure the zip ties arent to stiff.
"...i told you i wanted the left-handed screwdriver not the right-handed one..." always let the mentors get their morning coffee or else they start getting angry and making stuff up.
2005 NASA VCU Website Excellence Award, 2006 NASA VCU Website Excellence Award, 2006 Capital Clash, 2006 Delaware FVC Regional, 2007 Ramp Riot, 2007 Virginia FTC Regional, 2008 NASA VCU Regional, 2008 Battle of Baltimore, 2008 Virgina FTC Regional
Unread 30-11-2009, 20:23
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: helix
If you have any, try using the pnuematic tubing that comes in FRC kit, it works great, and once balls get to the top of your helix, they bend so your helix-tube can keep rotating.
this worked great for out 2009 lunacy robot,
ps. If you need them to be stifffer, just shove zip-ties inside the pnuematic tubes.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 30-11-2009, 20:37
Chris is me's Avatar
AKA: Pinecone
Re: helix
You can use a little surgical tubing, right? That's fairly grippy. Prototype that if you want to try something other than zip ties.
You can get various different FTC legal zip ties of different stiffnesses, try stuff out. You want enough force that it will propel the balls, enough flexibility so that you can keep the helix running with balls at the top without forcing them through the shooter mechanism, and enough stiffness that balls will not roll out the bottom. If you've achieved this, maybe you don't need to look for more solutions.
This is assuming you're using a helix that goes "up". If you're using one that goes "down", test and see if you need anything other than gravity. You might not.
As for how to power it, whatever works best for your design. In FTC I preferred to use gears whenever possible (granted this was vex). They all get the job done.
Unread 30-11-2009, 22:36
ziggy!!!
AKA: josh T
Re: helix
yes we are doing a helix that does go up and not down and you make a valid point with the surgical tubing yes we are alloud to use that materials. as far as the different zip ties of stiffness could you sugest some zip ties that are not super stiff because we do want to keep out center post moving. we are going to probably use a PVC pipe as a center of the "helix tree"
Unread 02-12-2009, 13:24
ziggy!!!
AKA: josh T
Re: helix
we have no sort of pnuematic tubing at all so that was a great idea and we did see a lot of that in FRC but that is not an option for us
Unread 03-12-2009, 00:53
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: helix
I guess how you have the shaft driven really depends on the motors your using and the space you have. 1766 made a robot in 2007 that was a direct drive system and it worked great. The only problem was that we had about a 1 inch clearance in between the two motors. If you don't have room for it, there really isn't much loss in using gears. One suggestion is to mount the rotating center on a bearing so that the downward force isn't being applied to the motor. I know this might seem like common sense, but I've certainly overlooked things like this before. So far, I've gotten lucky. But I've been trying to not push my luck.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
pic: 1219's 2009 robot, King Helix lukevanoort Extra Discussion 7 23-03-2009 17:58
pic: THINK PINK incomplete helix Gabe Salas Jr. Robot Showcase 3 22-02-2006 18:18
flat sheet layout of helix? Bob Holmstrom Inventor 12 09-02-2006 07:21
Double Helix Jimbo5051 Inventor 3 08-02-2006 20:10
