Go to Post FIRST gives everyone lots of practice in getting used to late nights. - waialua359 [more]
Unread 03-12-2009, 16:29
friendsbalt friendsbalt is offline
FTC #3886
friendsbalt is an unknown quantity at this point
Re: [FTC]: Motor and Servo configurations aren't working
We have the exact same problem. While trying to fix it we accidentally deleted every file on the NXT, and now we have that same problem with every program we try to run. We have tried all different ports and chaining order, including only a single motor controller and still nothing works. We can't even start the programs directly from the NXT, even a program that has about 5 lines of code, just making the motors go. Well, as I was typing this we re downloaded the firmware onto the NXT and got a motor controller --> servo controller chain working. So try re-downloading firmware.
Unread 03-12-2009, 19:58
FTC Mesa Prep FTC Mesa Prep is offline
FREAKOUT
AKA: Ms Kitty
FTC #3979 (Combustors)
FTC Mesa Prep is on a distinguished road
Actually we got one motor working so we go in circles....no idea how we finally got it working .We tried reloading the firmware into the NXT brick. No improvement. Now we are trying to change the motor controller array....stuff.
Unread 03-12-2009, 22:11
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Double check your wiring, a lot of times the motor connections can come loose as well.
Unread 09-12-2009, 10:20
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Some tips..
Try and get all your motors defined as easly as possible, because changing the configurations after you've got a lot of programming done may be tricky.
When we change a motor setup (due to wiring changes) using the Motor Configurator, we then go into our teleop & Auto program and manually delete any references to those specific motors and re-add them. This may be unnecessary, but it gives us much more predictable results.
If you are just flailing and need a stable test, go back to the "Getting Started" manual that came in your kit. Wire up your left and right drives EXACTLY the way shown in the manual, and then download "TheMechanic.vi" into your robot. (It's in the labview Examples folder, and it's described in the manual)
This program tests the drive motors independantly and puts the bot through a predictable motion. It's the BEST way to verify that you are on the right path.
Note: it you need to post your VI, just delete the pretty picture on the Front Panel. This will reduce the size greatly.
Phil.
Phil Malone
http://www.GEARSinc.org
[FTC]: Looking for a working 2008 FTC program mjgard FIRST Tech Challenge 4 06-11-2009 11:52
Labview questions, using motor and pot as a servo martin417 NI LabVIEW 7 05-02-2009 16:43
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Robot not doing what we need it to, and printfs aren't working Bryan Herbst Programming 8 21-09-2008 20:58
