Go to Post don't be grumpy. No one is allowed to be grumpy during build. - JaneYoung [more]
Unread 04-12-2009, 07:44
Re: Cheap replacement for the Power Distribution Board
Originally Posted by AustinSchuh View Post
Al,
Ah, now that I go back and reread my initial post after reading your response, I can see how my post could be interpreted two ways.
Since the 08 robot's electronics got completely removed, we were thinking of wiring it up to to use the cRIO to test out new algorithms for control and just get it working again. We could almost just use the old fuse blocks which we have plenty of lying around, except that we need the 24 volt boost converter to power the cRIO.
Austin if you just tether then any of these options should work fine. Wireless, the access point becomes the biggest problem. So using Greg's option you could also add a third battery for the wireless. I am thinking this through, but my first guess is to put the batteries close together, and tie the negative leads together to prevent circulating currents from running the source voltage up and down for the cRio and the wireless.
Power distribution board does not give power to access point bitsoglass NI LabVIEW 3 17-02-2009 12:07
Power Distribution Board BrandonD-1528 Electrical 2 31-01-2009 11:30
Power Distribution Board - Red LEDs on scherbs17 Electrical 5 22-01-2009 16:04
Power Distribution Board making noises ravena Electrical 6 04-01-2009 08:41
5v LED on Power distribution board? Hadi379 FRC Control System 6 18-12-2008 15:59
