Go to Post Focus on solving the problem, not on being deliberately creative. If you effectively solve the problem, creativity is naturally leveraged as part of finding a great solution. - Jim Zondag [more]
Unread 04-12-2009, 23:57
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
Re: NXT Brick clicks - reset button pushed...still clicking
Hi,
OK, before I answer your question, I have a few for you. What programming language are you using? I have a lot more experience with RoboLab.
Have you contacted LEGO Education? If not, you might want to. They have GREAT tech support. They have helped me through many problems that I have had.
Have you re-downloaded the firmware? The "clicking noise of death" normally happens when you are in the middle of downloading the firmware. If you have not tried downloading the firmware, you should try it. You will hear the NXT starting to click--just let it go. Once it is done the NXT should make the powering up noise, and your computer should bring up a box telling you it is finished.
If that doesn't work, you really should get in contact with LEGO Edu. They really are a great resource.
Hope that helps!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
[FTC]: NXT Brick Issues mincus38 FIRST Tech Challenge 4 12-11-2009 03:03
LVMastery TipJar Video: Using LabVIEW with the NXT brick LVMastery Programming 0 08-10-2009 13:43
Help! Can't send files to NXT Brick via bluetooth Raptorace22 National Instruments LabVIEW and Data Acquisition 0 24-11-2008 16:39
Frozen NXT Brick. devinejohnny General Forum 2 05-11-2008 21:34
The brick clicks, nothing else JoeXIII'007 Lego Mindstorm Discussion 3 08-11-2006 18:57
