Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 03-12-2009, 10:37
JohnFogarty's Avatar
AKA: @doctorfogarty
Pneumatics Air Compressors and Such
Ok i have been a FTC programmer for the last 2 years and i will be doing FRC this year i understand servos and motors and all that fun stuff but...i have no idea how to work air compressors with LabVIEW at all any help?
John Fogarty
Unread 03-12-2009, 11:05
Re: Pneumatics Air Compressors and Such
The examples that come with LabVIEW for FRC include one that shows how to control the air compressor. It's straightforward and you should have no problem understanding it.
Unread 04-12-2009, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
To amplify Alan's comments, it is easy.
The compressor is either on or off, nothing in-between. You control it according to a "switch" that goes to a digital input. If the switch is "on" the compressor is off, and if it's "off" the compressor is on.
Easy enough, right? Be sure to read the rules when they come out though.
To actually control a pneumatic piston or something, you turn the "solenoid driver" output on or off. Again, quite simple. The design group will tell you what has to happen to turn "solenoid number X" on, or off.
The rest is the mechanical team's problem.
Unread 05-12-2009, 21:59
AKA: @doctorfogarty
hahaa this is great thanks guys
John Fogarty
Air Compressors bhsrobotics1671 Regional Competitions 22 09-03-2008 21:26
Pneumatics - what do we do with exhaust air? devaaki Pneumatics 13 10-02-2007 11:30
Pneumatics and air pressure Bomberofdoom Pneumatics 3 08-02-2007 22:30
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
Pneumatics-Extra Air Tanks archiver 2001 2 24-06-2002 00:13
