Go to Post Who needs daytime soaps when one can watch FRC matches? ;) - lkg9999 [more]
Unread 30-10-2001, 15:25
Steve Yasick Steve Yasick is offline
Should be teaching right now
FRC #0085 (B.O.B. (Built On Brains))
Steve Yasick is a splendid one to beholdSteve Yasick is a splendid one to beholdSteve Yasick is a splendid one to beholdSteve Yasick is a splendid one to beholdSteve Yasick is a splendid one to beholdSteve Yasick is a splendid one to behold
Smile Plastic Bender
Would you consider a plastic bender as precision machining?
Unread 01-11-2001, 23:42
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Plastic bender? Sorry, I don't know much about this tool or process. I would need to know more about it to determine if its what we would consider precision machining. I would caution you though to be careful - precision machining is only one of a few issues that could be considered not acceptable fabrication methods. When we decided to put this contest together, we tried to think of a way that would level the playing field for all of the contestants. In doing so, we decided that a kit of material that was easily fabricated with ordinary tools and equipment would keep the costs down and maximize the involvement by the students. That is why we advocate "bolt on" construction techniques and also require "no precision machining". Bending plastic sheets by heating and using a break is considered "non precision", a specialized piece of equipment that most schools would not have access to, is not. So, our answer depends on the method or equipment needed to bend the plastic.
Unread 02-11-2001, 07:49
Plastic Benging...again
The method we're using is a plastic bender. It's a bar that heats us, then we set the lexan over it, let it become soft and bend it. There are no jigs, clamps, or anything to bend it for us. Is that "percision", and is that legal?
Unread 02-11-2001, 09:11
jrukes jrukes is offline
no team (none)
jrukes is on a distinguished road
Where could a team purchase a plastic bender? That sounds like a really useful machine.
-Jason
Unread 02-11-2001, 11:37
Unregistered
Posts: n/a
This is allowable by my account. This can be replicated by anyone with a heat gun and a break.
Unread 02-11-2001, 11:53
Plastic Bender
The bender came from: FTM Inc. 6160 Cobblestone Rd. Placerville, CA 95667 (530) 626-1986. I could not find a web page.
plastic hubs and drill motors Will Camisa General Forum 4 01-03-2003 00:03
Plastic Retaining Rings Adam Y. Technical Discussion 9 15-01-2003 09:48
plastic boxes Suzy General Forum 6 12-01-2003 03:27
lexan bender JamesJones Technical Discussion 9 12-05-2002 18:50
Plastic Spur Gears Joe Canavan Technical Discussion 2 25-11-2001 01:45
