#16
Re: Cheap replacement for the Power Distribution Board
Just listening in, you could use 2 of the standard robot batteries in series, use 1 for primary power and series in the second one with the hot only connected to the cRio. For power flux, you could use a large capacitor or a group of smaller ones in parallel (>20,000microF Should work). This would offset the instant V-drop from the start or reveres of motors. (The primary 12 might drop to 8V and the secondary battery in series won’t be affected so it should output 12. 12+8 =20) That is within minimum operating specs for the voltage. Easy, 2 batteries, a few caps that can be found lying around or in power supplies…. It’s a bit jerry rigged I know but it looks like it should work.
p.s. The "secondary" battery would not need to be a full sized FRC battery, it could be any 12V, a smaller one would be a lot easier to fit in. Last edited by xanarchyx : 07-12-2009 at 11:57. Reason: idea |
#18
I would suggest that you look into a voltage doubler. This would give you double whatever the voltage is on the battery. I would also be sure to put in a voltage regulator circuit and some filtering, such as a capacitor. The motors on the robot cause a lot of EMI (electro magnetic interference) that can cause strange things to happen if you don't use a filter.
#19
Just so we can keep everybody calibrated, the robot battery voltage fluctuates during operation from over 13 volts to under 5 volts. Filters and regulators can not help on those issues. A voltage doubler works if the input voltage doesn't change and the load current remains fairly constant. The boost/buck regulator can handle these fluctuations and provide a fairly constant output.
#20
Agreed, I have to get back into this mind set, lab conditions are good only in the lab. The load current should remain fairly constant, but the voltage will be all over the map, you may look into pre-built regulated power supplies. I am unsure whether they are mad for this low of a voltage or even if they are whether they would be cheap enough.
Be sure before you hook it up to anything, have someone who is very knowledgeable with electrics look it over, if you are not comfortable doing it. Also be sure to hook a meter to it and make sure that the output is within tolerances of the device being plugged into it, do this while the robot is under simulated playing conditions. |
| Power distribution board does not give power to access point | bitsoglass | NI LabVIEW | 3 | 17-02-2009 12:07 |
| Power Distribution Board | BrandonD-1528 | Electrical | 2 | 31-01-2009 11:30 |
| Power Distribution Board - Red LEDs on | scherbs17 | Electrical | 5 | 22-01-2009 16:04 |
| Power Distribution Board making noises | ravena | Electrical | 6 | 04-01-2009 08:41 |
| 5v LED on Power distribution board? | Hadi379 | FRC Control System | 6 | 18-12-2008 15:59 |
