| Thread Tools |
Rating:
Display Modes |
#16
Re: Proper Drafting Technique
I agree that drafting by hand absolutely helps to understand proper drafting techniques and standards. That being said, it's almost 2010 - time to go digital people. |
#17
I once did 2 or 3 sketches inside an hour, by hand (pencil, paper, ruler). I was able to turn 2D sketches into 3D interior/exterior view just by changing the line. 2 years later, one of the sketches is still floating around the team I did it for. Still no CAD for that one, that I know about...
Until CAD software can take a pen/pencil drawing and turn it into a 3D model instantly, both are very good topics to know. Now, if I had to do those sketches using a T-square and other drafting tools, it would take considerably longer. It's also harder to modify them well. CAD's strength is that you can change anything you need to and see how the parts fit together. Freehand sketches are fast, but usually not to scale. Drafting is to scale, but not fast. These days, I'd start with perspective and freehand, then move to drafting or CAD. |
#18
But I do agree about the editing bit. I know what its like to be awake for 48 hours straight, up all night working on drawings, only to go to class and have the professor whip out his sharpie marker and completely change your drawing...Its a real downer. But as far as editing...I don't know how much hand drafting you've done, but its usually not that difficult or time consuming to fix with an eraser and eraser shield. I also think that the consequence of having to change the drawing forces you to pay more attention to your design decisions while your drafting, I know it has for me. Thus making you an all around better draftsman. Hey, we got by for literally thousands or yeard with simple hand drafting just fine. It can't be that bad. |
#19
I'm far better at AutoCAD because I know the methods used by manual drafting. I know different techniques and can draw most any geometry without using advanced commands. If you can draft by hand with just circles and lines, then you can do the same on AutoCAD. The problem is that it is a lost art. I'm not saying every draftsmen should need to sit down and manually draft everything. However, I will say that they should have the ability and understanding to.
Also, a note on "crazy" stuff: Inventor sometimes does weird things when you don't use parametric(I often don't, so I can relate). However, I have never had this problem with AutoCAD. It does exactly what its told every time. You just have to be careful how your telling it what to do. If you don't tell it right, it might interpret a different command. In this case, the blame goes to the ambiguous input and not the computer's fault. |
#20
For me. CAD can be great for drafting. But there are times when you want to get a spacer made and a hand drawing only takes a minute if you know how to do it.
More important for me is that CAD tends to NARROW and FOCUS my thinking. This is good for detail design and drafting but death to brainstorming and broad concept exploration. Being able to sketch, render, and draft in multiple views by hand, is IMPERATIVE to getting concepts recorded, and shared with out the burden of knowing the little details of a concept. Even better is being comfortable combining BOTH skills. CAD drawings of known items (C-rio, wheels, motors, . . .) give you scale and hand sketching fills in the blanks. This is the "Paper Dolls" part of design, also know as "System Drafting". In any case, a drawing is important. You should never machine anything without having a drawing of some type to work from. |
#21
Oh I love working in CAD, I'm really interested in fundamentals of drafting though and I really appreciate the art of it.
#22
[offtopic]
I thought this was going to be a thread about cycling (i am a triathlete in spare time)[/offtopic] I would have thought its a bit of a balance between using a computer and hand drawing. On the computer you can easily modify it , can correct mistakes easily however you miss out on the good practise of doing it by hand so its a bit swings and roundabouts :| Last edited by Denman : 09-12-2009 at 04:34. |
#23
I just did a search for "mechanical drawing" at Abe Books. There are several older books (1930's through 1960's) for $3.64 each with free shipping. Perhaps some of those could be useful. A school library may have several older books available.
#24
Plan before you build (go figure?) We, the mentors, have mandated that no one picks up a tool until the concept is approved and the sketches are done. We'll see..... |
| Buzz's New Manipulation Technique? | Neo3One3 | Robot Showcase | 7 | 12-01-2007 16:07 |
| Mecanum Drive Technique | Dan Petrovic | Technical Discussion | 9 | 16-08-2006 20:42 |
| Maxi Block Wiring Technique | Al Skierkiewicz | Electrical | 0 | 06-02-2006 08:40 |
| Engineering or drafting? | crazykid234 | Inventor | 2 | 26-04-2004 12:41 |
| Programming technique.. | archiver | 2001 | 3 | 24-06-2002 04:02 |
