Go to Post First, corndogs and now cowbells... when will you make the pain stop, Frank?!?!?! - barn34 [more]
Unread 09-12-2009, 10:20
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: [FTC]: Motor and Servo configurations aren't working
Some tips..
Try and get all your motors defined as easly as possible, because changing the configurations after you've got a lot of programming done may be tricky.
When we change a motor setup (due to wiring changes) using the Motor Configurator, we then go into our teleop & Auto program and manually delete any references to those specific motors and re-add them. This may be unnecessary, but it gives us much more predictable results.
If you are just flailing and need a stable test, go back to the "Getting Started" manual that came in your kit. Wire up your left and right drives EXACTLY the way shown in the manual, and then download "TheMechanic.vi" into your robot. (It's in the labview Examples folder, and it's described in the manual)
This program tests the drive motors independantly and puts the bot through a predictable motion. It's the BEST way to verify that you are on the right path.
Note: it you need to post your VI, just delete the pretty picture on the Front Panel. This will reduce the size greatly.
Phil.
Phil Malone
http://www.GEARSinc.org
[FTC]: Looking for a working 2008 FTC program mjgard FIRST Tech Challenge 4 06-11-2009 11:52
Labview questions, using motor and pot as a servo martin417 NI LabVIEW 7 05-02-2009 16:43
[FTC]: [FTC]: RobotC Template Problem (causing an FMS issue) and Potential Servo Prob PackersFan FIRST Tech Challenge 11 26-01-2009 21:25
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
Robot not doing what we need it to, and printfs aren't working Bryan Herbst Programming 8 21-09-2008 20:58
